No brake lights or reverse lights
Old Nov 22, 2006 | 09:45 AM
idgit0488's Avatar
idgit0488
I have a 1979 F-150 I bought a few months back. The truck has no reverse lights or brake lights. The tail lights work though. The bulbs are ok as well as the wiring harness. I was looking on the side of my C6 tranny and there is no NSS. Just the shift arm and linkage. When I bought the truck the brake lights and rev. lights worked and I have not removed the switch, so it was like this when I bought it. Could I have a year model that the NSS is on the collumn? I'm pretty sure this tranny has been removed and rebuilt so chances are, the previous owner removed the switch and didn't reinstall it. Would the brake pedal switch have anything to do with this?? Thanks for any help. Also, the truck will start in gear.
Old Nov 22, 2006 | 12:12 PM
Mil1ion's Avatar
Mil1ion
You didn;t mention signal lights working or not.
Can you take a pic and put it in your gallery for me to see.
Maybe the PO put a special switch in for BU lights ?
The brake light switch maybe toast...It happens.
Do you have cruise control ?
Old Nov 22, 2006 | 01:10 PM
idgit0488's Avatar
idgit0488
The turn signals do work.
No camera to take pictures.
Contacted PO, he said he had not done anything, maybe another owner...
Does the brake light switch have anything to do with rev lights?
No cruise.
Old Nov 22, 2006 | 07:36 PM
Mil1ion's Avatar
Mil1ion
Brakes Lights vs BU lights ? No they don't, they are a seperate entity.
after you check Brake light fuse,
Look on the right side of the pedal arm.... there is a plunger button.
Check this for the button not coming out.
see illustration of switch here.
http://www.clubfte.com/users/mil1ion...trations2.html
Old Nov 22, 2006 | 10:00 PM
snowdog79's Avatar
snowdog79
Brake lights could very well be the switch, it's adjustable. I would suspect the NSS (it should be on the column) as I believe (someone correct me if I'm mistaken) it also worked in conjuntion with the backup lights on the autos.
Old Nov 22, 2006 | 11:49 PM
Mil1ion's Avatar
Mil1ion
His truck is a 79.
The combination BU Light/NSS was moved to the side of the C6 transmission in 1978.
1977 and earlier.
1978+
Old Nov 25, 2006 | 11:39 AM
idgit0488's Avatar
idgit0488
There is no NSS switch on the side of tranny. There is no wiring harness going to the area of the shift linkage.The brake switch is working fine, I am however having a hard time getting my circuit tester to work on the switch.
Old Nov 25, 2006 | 04:20 PM
Mil1ion's Avatar
Mil1ion
One side is hot the other goes hot when the button pops out.
FuzzFace2
1099
Jul 21, 2024 09:45 AM
bismic
Mar 9, 2022 09:20 AM
myakkacracka
13
Jun 16, 2016 11:33 AM
lmd91343
Feb 14, 2012 10:34 AM
RANGER589
18
Jun 3, 2011 10:03 AM
