Oil guage
Old Nov 22, 2006 | 08:41 AM
ctboyle03's Avatar
ctboyle03
Oil guage
My 2001 B4000 has developed yet another problem. When I start the truck after it's been sitting a while and the engine is cold, sometimes the oil guage sticks at low. I can turn the truck off and start it up again and it works normally. Also the other day, as I accelerated, the gauge jumped back and forth as I accelerated. I change my oil (i use synthetic) on a regular basis. Anyone else had this problem? Any advice?
Old Nov 22, 2006 | 08:47 AM
Bob Ayers's Avatar
Bob Ayers
Your oil pressure sending unit "switch" is bad. Keep in mind, it is not a true pressure gauge, it either will show no pressure, or half-scale, which happens when around 7 PSI of oil pressure causes the sending unit "switch" to close.
Old Jan 15, 2007 | 02:18 PM
ctboyle03's Avatar
ctboyle03
I bought a new oil pressure sending unit but now I cant seem to find where it goes. Anyone know the location on a 4.0L SOHC?
Old Jan 15, 2007 | 02:34 PM
blueranger99's Avatar
blueranger99
I have had the same problem - I just haven't had a chance to replace the oil pressure sensor. I think it's near the back of the engine towards the bottom of the block on the 4.0 L - I'm still searching for the one on my 3.0 L ....
Old Jan 15, 2007 | 02:36 PM
ctboyle03's Avatar
ctboyle03
If i find it i will definitely post pics to help others out. Going out to crawl under now and try to find it.
Old Jan 15, 2007 | 04:11 PM
ctboyle03's Avatar
ctboyle03
Well I wasnt able to see it...if anyone has a picture or other specific info on where to locate this please help!
Old Jan 15, 2007 | 04:23 PM
Bob Ayers's Avatar
Bob Ayers
The sending unit on the 3.0L is behind the head on the passenger's side. I have no experience on the 4.0L, but If I had to guess, I would look around where the oil filter is mounted......
Old Jan 16, 2007 | 12:21 AM
johnwaynejeep's Avatar
johnwaynejeep
Have you thought about switching to a mechanical oil guage? These are typically easy to install and are a lot more reliable then electrical ones. Just buy a decent one so you don't get stuck with crummy oil line connections, make sure your oil line is not near anything hot so you don't burn through it and develop a leak and you're in business.
Old Jan 16, 2007 | 09:01 AM
ctboyle03's Avatar
ctboyle03
Maybe a little later on down the road i will try the mechanical gauge. For now though, I just want to fix what's broken. And even if I switched to a mechanical gauge, I'd still have to figure out where the sending unit is located... still haven't been able to figure out where it is though.
Old Jan 17, 2007 | 04:44 PM
blueranger99
Thanks for the info. I'll check it out this weekend.
Do you have a photo of it ?
Old Jan 17, 2007 | 05:31 PM
Bob Ayers's Avatar
Bob Ayers
I don't have a picture of it, but I'll try and get a picture of it this weekend.
I've replaced mine with an analog sending unit, which is a lot larger than the
oil sending unit "switch".
Old Jan 17, 2007 | 06:15 PM
pawpaw's Avatar
pawpaw
Not sure where the oil pressure sending unit is on the SHOC 4.0L engine, but the OHV 4.0L engine illustration I have, shows it on the drivers side, about midway up the side side of the oil pan casting. So that should put it close to the drivers side engine mount area.
Old Jan 18, 2007 | 12:05 AM
Eric.S's Avatar
Eric.S
As long as the motor is nice and quiet, if you want to fix the gauge for free, i added a resistor into the line to fix the "low" oil pressure that the gauge displayed, Its typical of ford gauges.
Old Jan 18, 2007 | 01:40 AM
Level2's Avatar
Level2
Anyone ever wondered why Ford never puts an actual guage in their vehicles? Why do we just get dummy lights with needles? Even the gauges that do work have H or C hor H and L. Cant I get some numbers on these things? Is it so hard to put a temp reading on a engine temp guage or voltage numbers on the volt meter or how about some PSI readings for oil pressure? I have never met anyone that was overly fond of Fords gauge packages.
Old Jan 18, 2007 | 05:18 AM
Bob Ayers's Avatar
Bob Ayers
Any series resistance added to the line going to the sending unit, will make the gauge read lower....
