84 460 bent pushrod
Old Nov 21, 2006 | 09:54 PM
magwheels's Avatar
magwheels
84 460 bent pushrod
Still diagnosing problems, removed valve cover to find a bent pushrod #3 intake, loose rocker arm. Removed rocker, installed a pushrod from junk pile, cranked motor and it moves up and down. Is it safe to rule out a bad lifter? How can I tell if the valve is bent? Spring looks OK. Low compression, leakdown test: you can hear air through the crakcase
BADASS 65 RANCHERO
Mar 27, 2014 12:33 PM
Capt'n Phillips
Washington Chapter
15
Nov 15, 2013 12:23 PM
MikeWire
18
May 24, 2007 12:53 AM
HCarrer
Oct 18, 2005 05:13 PM
fordguy76
Mar 30, 2005 12:07 PM
