What else did I mess up?
Old Mar 22, 2005 | 10:39 AM
fordguy76's Avatar
fordguy76
I accidentally overtightened a rocker arm on my 71 429. It bent one of the pushrods. I have replaced the pushrod, but now there is a ticking sound. I can't figure out if it is the lifter or the valve. Does anyone have any advice. Also this is a brand new motor fresh from the machine shop.
Old Mar 22, 2005 | 11:23 PM
airharley's Avatar
airharley
Have you tried to find the source of the tick using a mechanics stethiscope? You can also use a peice of broom stick or a long screw driver. Place the screw driver against the area you think it is coming from. Then move it around until you get the loudest tick possible. You should be able to find the narrow it down that way. Remember that over tightening the rocker arms can cause the valve to slap the piston. Hence the bent pushrod. Two things could have come from this: 1 you broke a lifter (you didn't say mechanical or hydralic) or 2 you have damage on your connecting rod or piston. I would lean towards the lifter like you suggested.
Here's something else to think about as well... Sometimes an engine will come fresh from a rebuild with a tick. Someone may have lost track of what rod they were resizing, didn't use the correct rod bearing, or over ground the crank. These are just things to keep in the back of your mind not the rule.
Old Mar 23, 2005 | 03:30 PM
fordguy76's Avatar
fordguy76
They are hydraulic lifters. I don't think it is a rod or piston, I'm just hoping the valve isn't bent.
Old Mar 24, 2005 | 12:58 AM
deerhunter3814's Avatar
deerhunter3814
What about a cam lobe? Could it have suffered from this?
Old Mar 30, 2005 | 12:07 PM
fordguy76's Avatar
fordguy76
I figured it out. The rocker arms on the #5 cylinder keep coming loose. Sure am glad nothing major was damaged. I guess I can put some locknuts on the rockers to keep them tight. What do you guys think?
v8xploder
Feb 16, 2008 09:23 PM
papaearl
Mar 19, 2005 08:50 PM
cobradriver
Nov 15, 2004 12:49 PM
fordman428
Aug 30, 2004 09:02 AM
thepieceworker
Aug 23, 2004 09:31 PM
