bent pushrod
Old Oct 14, 2005 | 12:41 PM
HCarrer's Avatar
HCarrer
bent pushrod
I drive a 1995 Flareside with a 5.0 EFI engine. After hearing a cleacking noise and discovering (1000 Km away from home) that I was running on 7 cylinders, I drove (carefully !!!) back home and after checking spark plugs and cables, I took off the valve cover and found one "loose" rocker. I took it off and found that its pushrod was bent. Can any one tell me how to investigate the cause for the bent pushrod ?. What should I do next ?.
Thanks for any help !<!-- / message -->
Old Oct 14, 2005 | 06:42 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Oct 15, 2005 | 12:20 AM
Polkat's Avatar
Polkat
A bent pushrod is almost always caused by some restriction in the valvetrain, such as a badly sticking valve, a lifter stuck in pumped up position, a valve hitting a piston, too much play causing the pushrod to wack the rocker, and so on. Causes could include dirt in the oil or an engine running too hot.
Old Oct 17, 2005 | 01:10 PM
HCarrer's Avatar
HCarrer
Thanks Polkat. I found out that the spring for the same valve was broken. I suppose it was metal fatigue that caused the whole problem. I have changed the spring, straightened the push rod and am now up and running. Thanks for your help.
Old Oct 18, 2005 | 04:30 PM
Polkat's Avatar
Polkat
Just another thought....depending on the amount of bend, once a pushrod is bent, and then bent back straight, it may tend to suffer a fatigue which will make in more succeptable to bending again in the future. If you get the chance, you may want to replace that rod.
Old Oct 18, 2005 | 05:13 PM
HCarrer's Avatar
HCarrer
Indeed... I would have replaced it but could not find the spare part here in Cordoba. Lets hope it holds until something else brakes !!
Best wishes.
dyoungen
20
Oct 9, 2012 11:18 AM
videomkr
Apr 21, 2006 06:47 AM
JLinder2
Dec 13, 2005 02:39 PM
highrider76
Mar 29, 2005 08:53 PM
fordman428
Aug 30, 2004 09:02 AM
