ENGINE I.D. FOR 53 VIN #
Old May 31, 2002 | 09:46 AM
KINGBIRDDOG's Avatar
KINGBIRDDOG
CAN SOMEONE GIVE ME AN ENGINE ID FOR THIS TRUCK 1953 VIN#18CLS-227 ALSO WERE CAN I GET PISTONS ,RINGS,BEARINGS,AND GASKETS
Old May 31, 2002 | 10:06 AM
ranger pat's Avatar
ranger pat
Veteran: Navy
I may be wrong here, but that does not look like a normal truck VIN.
What model do you have? F-100 would be something like: F10D3P15087 where the 4 digit is engine size. D = 215 cubic inch OVH-6, M = 254 cubic inch L-Head 6 cylinder, R = 238 cubic inch L-Head 8 cylinder.
Old May 31, 2002 | 10:12 AM
mtflat's Avatar
mtflat
That's not a factory VIN. 239 flathead V8 or 215 ohv 6?
Parts suppliers for your needs include your local NAPA store, Mac's in New York, Patrick's in Arizona, Red's Headers in California, and Sacramento Vintage Ford in CA among many others.
Old May 31, 2002 | 05:40 PM
KINGBIRDDOG
IT LOOKS LIKE AN OVERHEAD VALVE SIX /WITH DISTRIBUTER IN THE CENTER,AND THE CANISTER OIL FILTER SLIGHTLY BEHIND THE DIST.I GOT THAT # OFF THE GLOVE DOOR IT ALSO SAID 91 HP
Old May 31, 2002 | 08:43 PM
mtflat's Avatar
mtflat
I'm confused, which is normal, but I need some more info. Please understand I'm not trying to be a wise-elbow.
This is a Ford? And is it a standard pickup, Courier, Ranchero, etc.?
The engine DOES have a valve cover, doesn't it? Your description of distributor in the middle with the oil canister behind, sounds like the 226 flathead with plugs and wires visible on top of the head.
Is the oil canister mounted vertical on the driver's side with a removable top for loose cartridge filters or is it mounted horizontally on the passenger side?
Also the 226 was rated at 90 and 95 HP. The overhead valve engines started at 101 HP.
The VIN you quoted doesn't match earlier Fords OR later ones. Check the top of the frame rails for a duplicate VIN. Should be something like F10D3K123456
Keep trying and we'll get there eventually. - tim
Old May 31, 2002 | 09:19 PM
46fordtruck's Avatar
46fordtruck
The Horsepower rating of 91, does it say certified (or cert.) net horsepower? That would account for a lower horsepower rating since the net hp rating is always lower than the brake horse power. Also, are there any other numbers on that tag, like trans, axle, or anything like that?
Gary
1946 pickup-ongoing project
1946 pickup-waiting for resto.
1947 pickup-parts truck
1957 Ford FL 500 Town Victoria
1970 Mustang FB-daily driver
1972 Olds Vista Cruiser-4 sale
1988 Bronco II-for sale
Old Jun 3, 2002 | 12:11 PM
54_5star's Avatar
54_5star
The plate in the glove box gives the net hp rating which is 91 for a 215 and 96 for the flathead v-8 In a '53.
Old Jun 3, 2002 | 01:25 PM
Kai's Avatar
Kai
blue_gill_slayer
1947 and Older Ford Trucks
Jul 13, 2012 11:51 AM
F.ROCK
Oct 19, 2008 11:47 PM
5356f100
Feb 7, 2005 06:13 AM
Flaflathead
Oct 5, 2003 10:31 PM
BEAVER
Oct 25, 2001 06:12 AM
