Headlight problems
Old Nov 20, 2006 | 04:51 PM
Fryman's Avatar
Fryman
Headlight problems
I have a 2002 Excursion and I cant get my headlights to shut off. I took out the fusses, disconnected the high and low beam switch, the light switch itself and they are still on. I had to diconnect the battery. Anyone have any ideas?
Old Nov 21, 2006 | 12:13 AM
madhatch's Avatar
madhatch
look in a wiring diagram for a relay. are both lights on? hi and low or can you toggle them? It would be very wild if its both because they use seperate relays. Its problaly your low beams. My truck is at home with the wife when I get back if no one has helped I will locate the relays and check it out.
Also is ther a high and low beam l/r fuse setup. civics have miltiple fuses.
mustangpt
Apr 22, 2015 09:59 PM
backacheacres
1947 and Older Ford Trucks
Jun 7, 2013 08:42 AM
dmp1983
Nov 4, 2012 11:28 AM
HowieE
Electrical Systems/Wiring
Nov 11, 2009 11:07 PM
s.squared-39
Mar 19, 2009 11:22 AM
