hard to start ...sometimes
Old Nov 19, 2006 | 12:06 PM
mike slattery's Avatar
mike slattery
hello i was looking for info on my 99 f 350 diesel and found this site. hope you can help. i turn the key on the wait to start light comes on then goes out right away then the service engine soon @water in fuel light come on. the tach needle goes to about 500 rpms. the truck cranks but wont start. i have replaced the glow plug relay,all 8 glow plugs cam sensor fuel filter and a oil change. sometimes the glow plug light acts normal and it starts fine. then it shuts off and acts wierd again. any ideas?
Old Nov 19, 2006 | 12:33 PM
spikebee's Avatar
spikebee
Have you had it checked for codes? It seems like that should set at least a history code.
Old Nov 19, 2006 | 12:35 PM
mike slattery
yes i hade it checked and it had no codes
Old Nov 19, 2006 | 01:37 PM
Green_Dually's Avatar
Green_Dually
Are you sure it was the glow plug relay that you replaced.Cause the AIH relay looks identical to the glow plug one.
Old Nov 19, 2006 | 02:02 PM
mike slattery
there are two relays next to each other on the motor. one is taller the shorter one is for the glow plugs
Old Nov 19, 2006 | 09:50 PM
mike slattery
what is the aih relay
Old Nov 19, 2006 | 09:54 PM
Tenn01PSD350's Avatar
Tenn01PSD350
AIH relay is just there to heat the air going into the engine for better/quicker warmups. Should not be your problem although it makes a good emergency GP relay in a pinch. Mine has been disconnected for over a year.
Old Nov 19, 2006 | 10:00 PM
mike slattery
thanks, thats what i thought it was
160buck
Jan 15, 2016 10:07 AM
tommyl
Nov 11, 2014 11:18 AM
Tom Callan
Apr 19, 2013 07:20 PM
hunterguy86
15
Jan 20, 2010 05:30 PM
samthemountainman
Oct 1, 2006 09:03 AM
