Glow Plug indicator light issue
Old Apr 19, 2013 | 06:45 PM
Tom Callan's Avatar
Tom Callan
  1. 1993, F 350, 7.3 IDI, E4OD, 4x4. The glow plug indicator light works sometimes. Replaced the glow plugs and still no glow plug panel light when I go to start up. Engines always starts right up, but I'm uncertain how to check this indicator light circuit. The relay seems to be working but not the glow plug indicator light. Need ways to check this circuit, please help.
Old Apr 19, 2013 | 07:20 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
https://www.ford-trucks.com/forums/1...-tutorial.html
wait to start light lamp diagnoses
if the WTSL remains ON
unplug the connector at control unit.
turn ignition switch ON.
if the WTSL goes OFF,disconnect the ground cables to batteries and replace the control unit.
if the WTSL remains on,trace out and repair the wire to the indicator light.
if the WTSL doesn't turn on
connect a jumper wire from the harness side to ground.
if the WTSL remains OFF,replace the bulb or trace out and repair the wire.
if the wait to start light flashes rapidly
happens when two or more GP's are burned out
test for continuity (or via the test light method as noted by Niles above) and replace as needed.
big island
Oct 21, 2013 11:25 PM
texasjack
Jul 17, 2009 08:09 PM
Glockem45
35
Mar 14, 2009 03:41 PM
cclc1021
Mar 10, 2008 01:24 PM
Thunderbox
Oct 26, 2004 09:00 PM
