wheels for dually
Old Nov 19, 2006 | 10:37 AM
bluthunder's Avatar
bluthunder
wheels for dually
does anyone make an oversized wheel and tire to replace the dual rear wheels?
Old Nov 19, 2006 | 11:06 AM
Dave Sponaugle's Avatar
Dave Sponaugle
There are three options.
Go with a large single rear wheel.
Run spacers between the wheels that you would use to run dual wheels on a single rear wheel truck.
Stay with the stock size.
Your choice may change your ability to carry weight.
You have to have clearance between the tires when the truck is loaded, or you will blow the tires from heat buildup.
Old Nov 20, 2006 | 12:11 AM
banks7.3's Avatar
banks7.3
are you wanting to go to a wide single rear wheel, or wider dually wheels?
check out wheel shops that build custom steel wheels like stockton wheel.
http://www.stocktonwheel.com/
Old Nov 22, 2006 | 08:22 PM
bluthunder's Avatar
bluthunder
sorry for the slow response, my computer had a bad spell. i am interested in going with a wide single on the rear. the trailer i haul only weighs 5,500 so this is not an issue for me.
Old Nov 22, 2006 | 11:54 PM
Nick-FM's Avatar
Nick-FM
off topic. Have you got stuck with your four wheel drive daully? i have the same truck but it's two wheel drive. i get stuck in anything off road. want to make it four wheel drive but it will cost an arm and leg. different trans., transfer case, drive shafts, front end, (tires, axles, leaf sprinps) steering box cloum. everything. BE cheaper to buy a new truck.
Old Nov 23, 2006 | 08:10 AM
bluthunder's Avatar
bluthunder
I have never been stuck with this truck. if not for the four wheel drive, i would have plenty of times.
harrisford
British Columbia
Feb 10, 2008 11:00 PM
Newsheriff706
Oklahoma Chapter
Jun 16, 2007 07:27 AM
JCwarrant
Bronco II
Feb 21, 2006 06:28 AM
Apr 13, 2004 12:08 AM
doug
Oct 11, 2001 07:42 PM
