No Start
Old Nov 16, 2006 | 09:06 PM
MADSEN's Avatar
MADSEN
No Start
New To Me Truck 2000 F450 Powerstoke Drove It 200 Miles Then Stopped In A Walmart Parking Lot. Srarted It Back Up And Started To Drive Off And It Died.will Turn Over But Not Fire
Have Fuel And Put On A New Filter.
No Check Engine Light
Its Dark And I Need Some Ideas Of What To Check
Help
Old Nov 16, 2006 | 09:32 PM
big5inch's Avatar
big5inch
Probably a bad camshaft position sensor.
Old Nov 16, 2006 | 09:59 PM
MADSEN's Avatar
MADSEN
Would That Send A Check Engine Light
Old Nov 16, 2006 | 10:14 PM
kbeefy's Avatar
kbeefy
mine did when it went. When you crank, does the tach move? I think if it doesn't it means the cps is bad, but get confirmation before you blow $100 on it.
On the other hand, it's always good to have a spare... it'd eliminate that from the possibilities.
If you can't wait for the $60 one off ebay, you might get a better price on one from the International dealer. Don't buy a carquest one, theres been several that didn't work. Can't speak for the other suppliers.
Old Nov 16, 2006 | 10:20 PM
Pocket's Avatar
Pocket
Usually when the CPS dies suddenly like that, it won't set a code.
99% sure that you need a new one.
Old Nov 16, 2006 | 10:23 PM
MADSEN's Avatar
MADSEN
FORD DIESELS ARE NEW TO ME . ARE YOU SAYING CAM SENSOR OR CRANK ?
TIA
john
Old Nov 16, 2006 | 10:24 PM
Pocket's Avatar
Pocket
CPS - Camshaft Position Sensor
It's mounted on the front of your engine just up and to the left of the crankshaft pulley. Takes a 10mm socket to remove.
Old Nov 16, 2006 | 10:30 PM
MADSEN's Avatar
MADSEN
I will check it tomorrow .
Thanks
JOHN
Old Nov 16, 2006 | 10:31 PM
mjlewis's Avatar
mjlewis
mine just went out and got my replacement on ebay.
http://cgi.ebay.com/ebaymotors/NEW-F...QQcmdZViewItem
Old Nov 17, 2006 | 01:00 PM
MADSEN's Avatar
MADSEN
put a new cps on and that was not it.
Now what ideas or things to check?
Old Nov 17, 2006 | 01:15 PM
Uzumati's Avatar
Uzumati
Madsen this is going to be a long list of check that must be gone through.
1. Drain fuel bowl the leave the valve open and turn the key to on. There should be a strong steady stream coming out the end of the drain tube.
2. Check oil level on dipstick, in hpop reservoir, and how many miles on the oil?
3. If 1 & 2 check OK unplug ICP sensor (Toward the front of the driverside head between th eHPOP and valve cover) and see if the truck will crank in "Limp Mode"
Post results and we'll go from there
Old Nov 17, 2006 | 01:20 PM
JFH's Avatar
JFH
If you have plenty of juice in your batteries then I would check the GPR - Glow Plug Relay. Also check your fuses. I had various issues over the years, usually it was the batteries for me but I've also had the CPS and GPR go out.
Old Nov 17, 2006 | 01:29 PM
Pocket's Avatar
Pocket
I doubt it's the batteries or glow plug system, since it died while you already had the truck running, plus you were at the store, so I'm assuming the engine was somewhat warm when it died. That's a good way to rule out the batteries and glow plugs as a potential cause.
Amiller has some good items to check. Also check your fuses like JFH suggested.
If everything there is ok, you'll need to get a diagnostic run on your truck. I would suspect a wiring harness problem, or an IDM problem.
Old Nov 18, 2006 | 02:52 PM
MADSEN's Avatar
MADSEN
ok so I have tried all the suggestions and still no start. new cps and the tack does move. oil is ok high preasure oil is ok the fuel pupm energizes and it continues to run when you crank.
SO now what ?
we found a diablow sport chip and took it off . we have charged the batteries
glow plug switch is working and gets hot.
help
john
Old Nov 18, 2006 | 04:52 PM
MADSEN's Avatar
MADSEN
ok so I went and got a new CPS and put it in
used some ether and got it to start
it runs fine once started but will not restart unless it gets a shot of ether
help I need some ideas of what to check
JOHN
