What do you weigh?
Old Nov 16, 2006 | 06:48 PM
TwelveAlpha's Avatar
TwelveAlpha
What do you weigh?
I know. Sounds weird, but lately since I've been around here, I'm seeing numbers now and then, and they always look so low. I know what the door says. I think I always assumed that info on the truck, whatever info, would be accurate. But then, what was that mpg rating on the window? Yeah, so anyway.
Heres the thing. Yes, my truck isnt stock anymore. But the things I've changed, they aren't heavy. I mean, changing a turbo. Okay, maybe you gain a pound. Or the intercooler. Nothing here is heavy.
But since my truck is a work truck, periodically, I have to go by a scale. At the dump they weigh me, on the interstate they weigh me (if I have a trailer).
So I know what the scale says I weigh basically empty, which is 9760 last time. And I was almost out of fuel.
What perplexes me is this seems higher than what I'm hearing from anyone else. Never bugged me until recently.
So what would you expect a crew cab long box to weigh in at?
Old Nov 16, 2006 | 06:58 PM
Kwikkordead's Avatar
Kwikkordead
When I purchased my truck I had to scale it because it is a 550 and it weighed 9700 lb completely empty and without the 5th wheel hitch installed. Since then I've put in a 98 gallon auxiliary fuel tank that adds about 730 lb when full and then there's the hitch that is about 50 or so lb.
Old Nov 16, 2006 | 07:04 PM
Pocket's Avatar
Pocket
I'm weighing in at just a hair under 8000 lbs. That's with 1/4 tank and my 195lbs hot sexy body sitting in the driver's seat.
By hot and sexy..... I mean't my wife.
But she's not 195 lbs.
Doh!
Old Nov 16, 2006 | 07:24 PM
jtharvey's Avatar
jtharvey
My CC LB F-350 weighs in at about 7800 pounds as it sits now, with the bigger tires, toolbox, & full fuel tank. I think your 9670 is extremely high and the scales are off. I've not even seen some CC LB duallys weigh in at much over 8000 pounds when empty.
Old Nov 16, 2006 | 07:41 PM
clux's Avatar
clux
Mine's usually about 7800 and some change with typically 300 lbs of tools/stuff in it. I also know I can carry 300-600 lbs of mud on the outside if it is really muddy.
A friend of mine's F450 cc with a flatbed weighs about a ton more (9800).
Old Nov 16, 2006 | 07:44 PM
Don Tim's Avatar
Don Tim
I have a 2000 4x4 SB PSD with Transflo aux tank Ranch hand bumpers front and rear, weighs in at about 8300
Old Nov 16, 2006 | 07:48 PM
Jakeman68's Avatar
Jakeman68
My F-350 Crew cab, short box, 7.3 4x4 with a toolbox and 35" BFG's weighs 7400 even with a 1/3 tank fuel.
Old Nov 16, 2006 | 09:26 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
8670 last time I scaled, but that was with me in the seat, so subtract 300 lbs.
Fresh off the showroom floor and <1/4 tank of fuel it was 7820.
Old Nov 16, 2006 | 10:46 PM
Fire Rooster's Avatar
Fire Rooster
7643lbs. truck,Me at 230lbs, a full tank of bio, and a set of firefighting turnouts
Old Nov 17, 2006 | 10:20 AM
trakman's Avatar
trakman
7740 with a tool box and an empty 130 gallon heavy duty "L-Shaped" fuel tank...2002 Super Cab short bed 4X4.
Old Nov 17, 2006 | 01:26 PM
Uzumati's Avatar
Uzumati
Man thats a light set of bunker gear!
I run around 7400 with a full toolbox
Old Nov 17, 2006 | 03:35 PM
DaveWilliams's Avatar
DaveWilliams
Thumbs up Certified weight
I have a 2002 F-350 Dually. It has the 38gal tank and it was slammed full and I have a Reese 16000 pound rated fifth wheel hitch. I weighed the truck, trailer and me for a total gross of 16,900. I drove 5 miles home, dumped the trailer and ran right back to the scales, and the truck weighed 7620 with me in it. So given the total weight was 16,900 - 7620 the truck weight, leaves me draging a 9280 pound trailer. I would guess maybe the weight of half gallon of fuel would be the amount burned off, but I would say that this is the accurate weight..
Old Nov 17, 2006 | 05:16 PM
RAMPAGE_F350's Avatar
RAMPAGE_F350
2002 crew cab dually 4x4 with gooseneck, toolbox, grill/brush guard, warn winch, full bag of fuel and me = 8217 pounds.
Old Nov 17, 2006 | 07:44 PM
spunks00's Avatar
spunks00
7500 lbs...Stock 99' F-350 CC LB SRW 6Spd 4x4, thats with about 450lbs in the cab (2 guys and gear)
Old Nov 17, 2006 | 07:45 PM
spunks00's Avatar
spunks00
7500 lbs...Stock 99' F-350 CC LB SRW 6Spd 4x4, thats with about 450lbs in the cab (2 guys and gear) my old 84' single cab long bed chevy diesel 4x4 was 6100 lbs
