Looking for the cheapest clear tail-lights
Old Nov 16, 2006 | 06:41 PM
scottman70's Avatar
scottman70
Any ideas, I was on E-bay and found some for $65 anyone found them any cheaper??
Old Nov 17, 2006 | 12:10 AM
RACERX7775's Avatar
RACERX7775
just remember, you do get what you pay for.....
Old Nov 17, 2006 | 08:43 AM
vettdvr's Avatar
vettdvr
I thought clear "white" light from the rear was illegal and not for road use. But then I might be mistaken. Jim
Old Nov 17, 2006 | 08:23 PM
ramsmoker's Avatar
ramsmoker
Talking lites
Just an idea, On my wifes Passat I used red led bulbs. They look great. On my X I left the stock lights in but traced the light pigtail pattern in the upper part of the light, cut it out with a Dremel and wired up another pair of bulbs. This would also look good in clear.
Old Nov 18, 2006 | 11:50 PM
RACERX7775's Avatar
RACERX7775
no don't do that, i did it on mine and the factory bulbs on the top location melted the housing in less that 2 days. get the led red bulbs for the top if you do it. check my gallery, i have pics of a 4" round tractor trailer led light that was cut into the factory housing and the red led factory bulb moved to the top location. all my lights were swapped to led's. oh, if you do led's in the rear, you will need a resistor to slow down the blinker speed. because the led's draw so little power, the truck thinks that a bulb is out and blinks fast.
Old Nov 19, 2006 | 02:47 PM
ramsmoker's Avatar
ramsmoker
Talking Light's
I have had my tail lites done for over 6 months with no problem yet. I did the full led lites in my wifes Passat. You can't change the flasher so I had to use resistors. On the X I already changed the flasher. I used the motorized flasher from one of my Pete's. There not load sensitive to about 30 amps. There small and fit almost anywhere.
Kingkoopa
Sep 20, 2013 12:31 PM
vitocee
1997 - 2003 F150
Feb 12, 2005 02:24 PM
tlitteral
Apr 7, 2003 07:57 AM
okiewelder
Feb 26, 2003 09:29 PM
