I have lurked around and read a lot of good info, figured I'd join up.
Here's a pic of my current project:
I got it real cheap ($600.00). It came with a Holly projection system that I removed immediately and replaced with an edelbrock performer 750cfm carb. Engine is a 460.
I plan on doing a 4" lift, bigger tires, new exhaust, body work and a paint job.
I read here somewhere that I can use seats from a 1996 (I think) or older truck and they'd bolt right in. I guess the stickies are gone now, so any links to good info would be apreciated. I don't want to clog up the forums with dumb questions.
I'd say the body or engine alone would be worth what you paid for it.
Seats up to a 96 will bolt in place, and newer seats will fit, just need to play with the brackets.
What year F250 is it?
What size tires you plan on running?
You might want to check your diff tags(metal tags on the diff cover bolts) to find out what gears you have. IF you have 4.10 gears, then you'd be set for 35s, but if you only have 3.50 gears, then you might want to think about doing some engine work, or regear for the bigger tires.
A 4" lift will clear 36s pretty nice.
Good luck in the junkyard. I can spend hours in the junkyard getting all kinds of little things.
Nice find, looks like a steal for $600. The newer seats will bolt right in, all you need to do is use the brackets off of your original seat, which bolt directly to the newer seat, and then everything will fit the original holes in the floor.
Btw, you mentioned that you immediately removed the Projection unit. Can you elaborate as to why? Was it personal preference or did it not work right? What are you planning to do with the projection unit? I am curious because I have been considering this setup for my '79 460.
Boy!! Can't go wrong for 600.00 bucks. Looks like a really nice truck. Can't see the other side, but if it looks anything like the drivers than a little work and it can be awesome. Good Find
The topper is probably worth 600.00, the truck could be worth 6000.00 with a little elbow grease.
Start your gallery and post pics as you go, looks like you got a winner!
No idea how to start a gallery, will check into it. The truck looks decent all the way around.
I will look tomorrow and see if I can't figure out the gear ratios
I pulled the projection system for my convenience. I want a simple truck that I can repair myself. The projection system, if it ever failed, would leave me stuck. Now I can carry minimal parts and fix it myself. I traded the projection system for the 750 edelbrock carb.
To start a gallery, the only/easyest way I know is to go to the top of the page where it says quick links, click on that, then go to edit options, then go to edit profile, then go to edit/create profile, then upload some pics from a saved file on your computor and you've got it.
I have a friend who has a very similar truck. His has the 460 in it too, and he put a dual exhaust on it. To say a lot with a little, you can hear his truck from a long ways away.
