Change to a different trans
Old Jan 2, 2017 | 11:22 PM
RIKIL's Avatar
RIKIL
ok, third time is a charm...this is the third E4OD I have torn up with my motor and I want to try something different.
Right now I have:
351W -> E4OD -> Borg Warner 1356 x-fer case -> 3.55 rear end
I want to change to a 4r70w but not sure what transfer case will work or what other adjustments will be needed (drive shafts)?
Old Jan 3, 2017 | 07:47 AM
Freightrain's Avatar
Freightrain
What are you hurting?
I know places like Lentech can build a pretty stout AOD that the mustang guys would use. A friend runs one behind a 427ci Windsor in a 75 F100.
I would think the E4OD would be worlds better and stronger overall. Just too big for a car.
Old Jan 3, 2017 | 08:05 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
You'll need a computer to make it shift. There are aftermarket computers that will work with a 4R70W.
Old Jan 3, 2017 | 08:08 AM
Diesel_Brad's Avatar
Diesel_Brad
Why not just have the e4od rebuilt instead of putting used ones in
Old Jan 3, 2017 | 10:08 AM
RIKIL's Avatar
RIKIL
I have that now with the E4OD
Old Jan 3, 2017 | 10:17 AM
RIKIL's Avatar
RIKIL
I agree the E4OD is considered the more heavy duty trans and ts true the e4od/4r100 is much heavier built (and slower) but the 4r70w is more than capable of doing everything the bigger trans can.
A 427ci windsor in an F100 (assuming it has the biggest carb possible) is probably putting out 420 or 450 HP if na. Those numbers are just a little less than what my motor produces now. Mustangs are built to handle the power so I have to think it is possible.
Old Jan 3, 2017 | 12:41 PM
Diesel_Brad
A mustang is also much lighter than your pickup
Old Jan 3, 2017 | 02:25 PM
Freightrain
Yes, the Windsor made 500 hp at the flywheel n/a.
Agree, the weight of a 4x4 truck will likely not be good on a smaller transmission.
I just don't see why the E4Od won't survive? What is breaking? Are these all "used" transmissions? Or rebuilt to a specification to make them survive. There are guys with turned up PSD's that have no issue with them.
Old Jan 3, 2017 | 02:35 PM
RIKIL's Avatar
RIKIL
Internally I have no idea what is going wrong (the last two transmissions will shift out of second but never catch into third gear). I don't think it is wise for me to think I can open the thing up and repair it so I always took it to someone else. What is different now is that, whatever I go with, I can get it locally so if there is an issue, I will just go back to the same place. Obviously it isn't as easy to do when the trans comes from Florida.
A guy locally I talked to convinced me he could build a strong enough E4OD like what would go behind a diesel but I am starting to lose faith in the ability for my E4OD to hold up since this is the 4th rebuild.
Old Jan 3, 2017 | 05:57 PM
NotEnoughTrucks2014's Avatar
NotEnoughTrucks2014
No you don't. Listen to Mark, he knows what he is talking about.
Old Jan 3, 2017 | 06:04 PM
RIKIL's Avatar
RIKIL
Here is the interface for the software I use to adjust my trans...do we still need to discuss this now?
Old Jan 3, 2017 | 07:05 PM
Conanski's Avatar
Conanski
See that sounds like an electronic control problem, the probability of having the exact same mechanical problem with 2 different transmissions is next to zero and that false neutral sounds an awful lot like something that would result if there is a problem with the MLPS sensor. We have been saying this here for years, these transmissions are 100% computer controlled and you have to make double sure you don't have any electronic control issues before going into the trans or you just may waste a whole ton of money fixing something that isn't broke. Now there are some known weak points with the early E4ODs but I don't know if they manifest themselves in that manner, an E4OD expert could advise you better.
For clarity have you actually had the exact same trans rebuilt 3 times or have you had 3 different transmissions in the truck? In either case converting to a later E4OD would be easier than swapping to a 4R70w as that would require a different PCM and wiring changes.
Old Jan 3, 2017 | 07:13 PM
Conanski's Avatar
Conanski
He wasn't talking about a tuning computer he was talking about a control computer(PCM), are you using a Ford PCM or something aftermarket?
Old Jan 3, 2017 | 07:24 PM
RIKIL's Avatar
RIKIL
The first trans that failed was the one that came with the vehicle in 92. That was rebuild by Ford at about 80K miles and was fine for the next 16 years or so. The second and third failure were the same trans, a custom build to "handle" the power. - I removed it and sent it back after the second failure and reinstalled it (with a new torque converter). https://www.ford-trucks.com/forums/1...ix-or-not.html
1 month after I got the latest trans installed, I had a trans flush because I wanted to make sure the solenoid pack remained clean.
I really do understand what you mean about making sure all the electronics are sound, it is something I will triple check.
Old Jan 3, 2017 | 07:27 PM
RIKIL's Avatar
RIKIL
I am using a U4P0 ECU, it doesn't control the trans at all in my application. The trans controller reads the RPM, TPS, and VSS to control the solenoid pack. Its the older Baumannator TCS - http://www.becontrols.com/downloads/bectcsinstall.pdf
