I have been using Firefox for a long time with no problems. But the other day I lost my bookmark feature. Is this something I did or what? I reloaded Firefox but no change. Ideas?
I used to lose my profile quite often, and it would be like starting all over again. Here is the info i keep in a word doc on my desktop.
In order to create a new profile, you use the Profile Manager. To start the Profile Manager in Windows, follow these steps:
1. Close Firefox completely (select File > Exit from the main menu of Firefox).
2. Select Start > Run... from the Windows Start menu.
3. Enter firefox***** -profilemanager and press OK.
On Linux or Mac, start Firefox with the the -profilemanager switch, e.g. ./firefox -profilemanager (this assumes that you're in the firefox directory).
You should now see the Profile Manager window, shown in the screenshot to the right.
From the Profile Manager you are also able to remove and rename profiles.
I hope this helps you. By the way, since I upgraded to firefox 2.0, I haven't had any problems with this.
