Timing made it worse?
Old Nov 15, 2006 | 09:39 PM
Fal Grunt's Avatar
Fal Grunt
My truck has a boatload of problems, one of the being that it runs VERY poorly, no power, and terrible gas mileage. Well the suggestion was to adjust the timing. OK. So my dad and I adjusted the timing, which is a great thing because it was at 18deg BTDC. Well we adjusted it to 10deg BTDC and it ran great with the spout disconnected (what we are pretty sure was the spout) but then over the last week it has started running TERRIBLE. Not only does the engine run terrible now, the transmission has started acting up agian, the same as before I changed the MLPS (that solved the problem)
Threads about my problems :
https://www.ford-trucks.com/forums/5...eak-460-a.html
https://www.ford-trucks.com/forums/5...-problems.html
So... what did we do? I have stretched my knowledge to the limit.
HELP!? I don't know what more to ask, what more to tell, and I have stretched my mechanical knowledge to the limit.
I appreciate the help. -myers
Old Nov 15, 2006 | 10:19 PM
EPNCSU2006's Avatar
EPNCSU2006
If it wasn't pinging at 18 degrees, I'd put it back there. It's possible that the timing marks moved and that was the correct place. To a point, the more advanced you can run without pinging/detonation, the better performance and fuel mileage you will achieve. If the timing is too retarded, performance and fuel economy will suffer drastically.
The SPOUT connector should be in the wiring on the drivers side fender near the ignition module (the small thing with a heatsink around it).
Old Nov 15, 2006 | 10:52 PM
pfogle's Avatar
pfogle
Okay, here's a few things that WEREN'T mentioned in the other posts. Catalytic converters, are they still there? If so unbolt the exhaust from the manifolds (don't remove the manifolds from the heads) and drive it around the block.. It's going to be LOUD so do it at like noon on a wednesday when everyone is at work. If you have a marked improvement in power you've found your problem. Spark plugs, what brand, how old, and were they gapped properly before installation? Then what about the TFI? It's what controls the timing. If it's starting to go it can cause these problems, in '94 it should be on the drivers side fenderwell, or drivers side of the firewall (bulkhead).
Old Nov 16, 2006 | 08:44 AM
quicklook2's Avatar
quicklook2
a quieter way to test for clogged exhaust is by using a vacuum gauge.
Old Nov 16, 2006 | 10:53 AM
subford's Avatar
subford
I have some questions:
1. What size engine was in it before you put in the new 460?
2. If it was not a 460 and you seem to hint it was not what did you do about the wiring and the PCM?
3. Did you fix the transmission or is it still bad?
4. Is the transmission a 94 or a 96?
Old Nov 17, 2006 | 12:23 PM
Fal Grunt's Avatar
Fal Grunt
pfogle
The cat is still there, though not really. We knocked the insides out, before everyone goes legal on me, where I live there are NO smog provisions.
Spark Plugs are Bosch Platinum II's, about 1month old, took them out of the box and put them in. (ran great after I installed these)
Don't know anything about TFI
subford
Always been a 460 (sorry to alude otherwise, probably from the fact that the old 460 was VERY shot, no oil pressure, no power, the heads have oil burnt and caked almost an inch deep. but this rebuilt engine has no more power... it's a little better, noticeable, but not what I (we) expected from a 460)
trans was a recent rebuild, and was installed when rebuilt engine was put in. (both came from a truck that was wrecked that had no problems prior to wreck, wreck was a VERY minor one)
Both engine and trans are a 96, wire harness and pcm(i think) were both taken from the 96 and installed with engine and tranny.
Thanks so much for the questions so far, I hope that they provide the info you need!
-myers
Old Nov 20, 2006 | 10:30 AM
Fal Grunt's Avatar
Fal Grunt
btt.... anybody? please!! i'll have all day wednesday to work on her...
-myers
Old Nov 20, 2006 | 10:54 AM
quicklook2's Avatar
quicklook2
take those crap bosch platinum plugs out today.
use good old motorcraft copper resistor plugs.
i bet a case of beer on this one.
Old Nov 20, 2006 | 10:56 AM
Fal Grunt's Avatar
Fal Grunt
Thats on my list to do wednesday. Unfortunetly these symptoms were present with the old motorcraft plugs in. Hopefully the plugs will help.
thanks for the input
So far so good, but I need more guys!!!
-myers
Old Nov 20, 2006 | 11:01 AM
quicklook2's Avatar
quicklook2
replace fuel filter, reset computer, bad engine to frame ground, plug wires.
Old Nov 20, 2006 | 11:27 AM
Fal Grunt's Avatar
Fal Grunt
fuel filter was replaced when we got the truck, about 4 years ago, has only seen maybe 6k miles since then.
Will reset computer while im replacing plugs on wednesday.
How would I check the ground?
Thought about plug wires... suggestions for brand?
-myers
Old Nov 20, 2006 | 11:35 AM
Kemicalburns's Avatar
Kemicalburns
run ford 9mm plug wires.
Old Nov 20, 2006 | 11:42 AM
Fal Grunt's Avatar
Fal Grunt
Are those available at Advance/Napa/etc?
Old Nov 20, 2006 | 12:18 PM
quicklook2's Avatar
quicklook2
check ground by unbolting them and cleaning and making sure no corrosion.
during engine swap maybe not hooked up ground from engine to frame or firewall.
Old Nov 20, 2006 | 04:51 PM
Fal Grunt's Avatar
Fal Grunt
Where is the ground located? -myers
