towing an additional trailer
Old Nov 19, 2006 | 06:31 PM
blackhat620's Avatar
blackhat620
Kwikkordead
Here is a link to state towing laws, and it shows Washington as a No.
www.hitchemup.com/statetowinglaws.htm
Hope this helps
Old Nov 19, 2006 | 09:15 PM
rvpuller's Avatar
rvpuller
Veteran: Coast Guard
Kwikkordead
In April when we leave SW Oregon I may get a permit encase we decide to come back next fall. We mite as well get everything wet .
Denny
Old Nov 20, 2006 | 06:55 AM
boomer 453's Avatar
boomer 453
Originally Posted by jake00
you could get a TT and toss the atv in the bed
I thought about the same thing but i was thinking a 5ver would let me go to a shorter overall length with the same length trailer.
thanks for all the help....much appreciated
Old Nov 20, 2006 | 09:13 AM
SLE's Avatar
SLE
You'r absulutly right! This is exactly why my next rig will be a fithwheel. With my TT I run 73' from the bumper to the boat prop! I plan on upgrading to a larger newer boat within the next couple of years which will push me right near or over the 75' length limit. The same length fifther will be at a minimum 7ft shorter! That may not seem like much but when you've got 75' of crap going down the highway and manuvering through camp grounds it makes quite a difference.
Old Nov 20, 2006 | 09:25 AM
Kwikkordead's Avatar
Kwikkordead
Originally Posted by blackhat620
Kwikkordead
Hope this helps
Thanks for that link. I guess I won't be doing that unless I want to go get a CDL.
Old Nov 20, 2006 | 02:35 PM
rvpuller's Avatar
rvpuller
Kwikkordead
This site is for pulling behind a TT not a 5ver, with just a fast look I can see 3 states that allow it with a 5ver. Two of them I have double towed in WI and KS.
Denny
Old Nov 20, 2006 | 04:11 PM
blackhat620
rvpuller,
FYI there are special restrictions on double or triple pulling in Wisconsin, and unless you have a CDL, or are a Farm vehicle within 150 miles of your farm or are a Tour train in your county, you cannot legally pull doubles in Wisconsin.
343.04
(2) VEHICLE TYPES. For purposes of this chapter, certain
vehicles intended to carry school children or other passengers, or
having special operating characteristics, are divided into the following
vehicle types specified in pars. (a) to (f):
f) Vehicles towing double or triple trailers. Vehicles towing
double or triple trailers are commercial motor vehicles with
348.07 Length of vehicles. (1) No person, without a permit
therefor, may operate on a highway any single vehicle with an
overall length in excess of 40 feet or any combination of 2 vehicles
with an overall length in excess of 65 feet, except as otherwise provided
in subs. (2) and (2a).
(2) The following vehicles may be operated without a permit
for excessive length if the overall length does not exceed the indicated
limitations:
(c) Forty five feet for mobile homes, motor homes, and motor
buses.
www.dot.wisconsin.gov/drivers/lawbook.htm
Bottom line use the reference chart i linked earlier as a quick guide and then check out the specific states DMV laws you will be towing through.
Also here is another link to a towing laws chart with footnotes and brief descriptions. If it is Footnote 43 it means special conditions apply before it is allowed.
www.towingworld.com/articles/TowingLaws.htm
Hope this helps
Old Nov 20, 2006 | 09:54 PM
rvpuller's Avatar
rvpuller
blackhat620
I don't trust any of the Internet sites I call the state before double tow, you also have to make sure you state with a 5ver not a tow trailer. And if its not legal in WI a lot of law enforcement didn't know it because a lot of them seem me. I've been towing double long before the net and I still check the old fashion way.
Denny
Old Nov 20, 2006 | 10:10 PM
jake00's Avatar
jake00
Kwikkordead
Hope this helps
I dont know how accurate that is, It says no for doubles in IL. but see ROADWAY pulling doubles all the time
Old Nov 20, 2006 | 10:14 PM
blackhat620
Originally Posted by rvpuller
blackhat620
Denny
Yes i agree you always have to check a states regs, in the case of Wisconsin, does not matter if it is a 5ver or TT. And yes many of the local law enforcement don't know some of the laws, or they could have known but let you slide because you were doing everything else correctly and they didn't want to stop you just to see if you had a CDL.
As far as the internet goes, the links i posted are the Wisconsin Government website with the actual full text of the state laws. I like to read the actual laws instead of relying on a phone call to a potentially mis-informed underpaid & overworked government employee on the other end of the line. If they make a mistake they aren't liable for your problem. Kinda like when you call the IRS with a tax question and they give you the wrong answer, then later down the road the audit you, find you made a mistake (base on the bad info you recieved) and they fine and penalize you for an improperly filled out form.
The internet makes it easy to see the full text of the state laws without having to drive down to the state government office and make photocopies.
Old Nov 20, 2006 | 10:19 PM
blackhat620
Commercial vehicles are not a good indicator as they have a CDL and permits so they can do alot of things a standard licensed driver cannot.
As far as IL goes last time i checked the state website, you could tow a second trailer if the first trailer was a 5vr and total combined length of tow vehicle and all trailer could not exceed 60 feet.
The links to the charts are just for quick reference, the state laws can and do change frequently. Always best to go to the state government websites and read the actual law. Especially if you are towing anything more than simple small trailer. Start towing heavy or exotic applications and the laws get complex in a hurry.
Hope this helps
Old Dec 3, 2006 | 10:45 AM
Flywest's Avatar
Flywest
75ft?
Someone oughtta tell this guy that!
I'm thinking a 5th wheel camper behind the Ftruck with this boat & trailer behind that again, might just be the "ideal" rig for a round Oz jaunt!
Wonder if my ol road train truck license will let me haul that combination downunder? Then again - would the Effie handle that sort of transport task?
Maybe it'd be time to upgrade to one of these!
Cheers!
Old Dec 3, 2006 | 11:57 AM
  #28
Yukon's Avatar
Yukon
I'd really have to jack up the 5er with that truck!
nwatkins176
New Member Introductions
May 20, 2014 10:55 PM
ottomandan
Apr 13, 2013 05:56 PM
cirrus365
All Things Towing
Apr 1, 2012 04:05 PM
xtmsports
13
Mar 31, 2006 06:26 PM
Jeepincj7
All Things Towing
Dec 6, 2002 05:51 AM
