Is there a difference? The E3 is from an 83, and the E5 is on my 86. Is the E3 compatible with my 86 E5? The description sounds the same, but I'm not sure.
Trying to figure it out within 2 hours, so any help is appreciated.
Could be anything, Air flow rate, fuel mixture ratios, internal workings, ports missing/added, different feedback solenoids, or could be something as simple as how a component bolts to it.
The rule of thumb is the Carb numbers should match exactly to your application.
