521 stroker buildup
Old Nov 20, 2006 | 09:53 PM
bronco521's Avatar
bronco521
Originally Posted by darrin1999
i personally like the edelbrock... they get a little better mileage than holley, dont have a power valve to blow out if it backfires through the carb, but they make slightly less power... so if youre for all out power then go holley, if you want a little better mileage and reliability go edelbrock... your choice
holleys are perfectly reliable and the newer ones have powervalve blowout protection.my opinion,holleys are the only way to go.
Old Nov 21, 2006 | 12:13 AM
monsterbaby's Avatar
monsterbaby
Opinions on carbs are just that, opinions, the newer holleys are a lot better with the blowout protection, the edelbrocks are better because they don't have any gaskets below the fuel level in the fuel bowls. For just plain street manners etc I prefer the edelbrock, for all out performance or even a hot street car the holley is better.
Old Nov 23, 2006 | 08:42 AM
Gary Blair's Avatar
Gary Blair
oil pan
Originally Posted by Brad Brown
Perfect info guys, I went down to the speed shop and cost out some parts, the crank kit is $1591,00 not bad! 4.3 stroker with H beam rods and forged pistons and rings for 9.6 compression and rod and main bearings.
Lucas, your right the oil pan is not cheap. $286 plus 75 bucks for the pickup. I think I will take your advise and look at the scrap yard first. 1/2 hour under a truck is cheap.
Do you guys know if these hedman headers will work in my 1974 crew? They are part number 89140. The guy at the shop said they would work fine. $213 bucks.
comp cam $142, lifters $89 mag rockers $176 push rods $126 double roller $54
gasket kit $95
another question, Is a macleod flywheel any good? and do I need the 176 tooth 15.52 inch one or the 180 tooth heavy duty? I think it was 28 oz.
That sucker is $495 wow.
But $3300 for a 521 stroker is not bad, plus machining and assembly. I am going to have to try to find a good shop to balance this thing up for me too. In Calgary, any suggestions???? EH? AHHAHAHAHAHAHAHAHA Thanks again for all the help.
If your 4x4 is going to be in some rough terain I would go for a deeper pan with some baffling. The Ford truck pan does not have any baffling. Take a look at Milodon too.
toysrus1966
Apr 23, 2014 10:47 AM
BRay09
48
Nov 17, 2011 10:33 AM
shadow_almanza
15
Sep 21, 2011 11:44 AM
vettman
Jul 24, 2011 12:40 PM
Brian460
37
Jan 27, 2004 04:01 PM
