defrost vs AC
Old Nov 13, 2006 | 09:46 PM
gillman's Avatar
gillman
defrost vs AC
How can i disable the AC compressor when i use the defroster ( hot or cold) ?
Old Nov 14, 2006 | 08:42 PM
Ultramagdan's Avatar
Ultramagdan
Why? The AC dries the air and make the defrost more efficent.
It wouldn't take much to put a on/off switch on the wire to the compressor though.
Old Nov 22, 2006 | 07:57 PM
gillman's Avatar
gillman
The answer to why, is that the AC / Compressor causes the engine to suck to much fuel when all I need is some air flow over the windshield to defog/defrost, especially in winter when the compressor (in my view) is unnessesary.
Thanx very much for the switch idea,though.
Old Nov 22, 2006 | 11:26 PM
Ultramagdan
The compressor is actually very efficent in winter because it dries the air. When you want to defog the windshield you want dry air to wick the moisture away. The compressor doesn't run that much, if you watch it, it cycles on and off and usually not for very long if the system is intact.
You can try to bypass it but I doubt you will see a fuel savings.
Old Nov 24, 2006 | 07:36 PM
MazdaRangerGuyInSTL's Avatar
MazdaRangerGuyInSTL
Any fuel savings you'd obtain would be so small you wouldn't even notice a difference.
If you're real worried about it, just unplug the low pressure switch for the winter.
Because the weather is colder, the compressor only actually runs for a fraction of the time, and runs at much lower pressures than in the summer, resulting in a very small load increase.
MTP55
Nov 15, 2016 12:13 PM
jstihl
17
Jan 18, 2016 09:25 AM
mappy881
Jan 4, 2016 06:37 AM
02GrayPowerStroke
1997 - 2003 F150
Jul 28, 2015 07:37 PM
Ricky Mayo
Sep 28, 2010 09:05 PM
