Bad Trouble Wont Start
Old Nov 13, 2006 | 06:25 PM
Don Tim's Avatar
Don Tim
Talking Bad Trouble Wont Start
Ok I will start by saying I am an Idiot. Trying to connect the Manual TC lock up circut my color blind eyes connected the ground to the number 10 pin red and yellow wire. Now it wont start, Anyone know what I did? Where does that wire lead to? I get a ICP and Boost error from my banks six gun tuner.
OH Boy !
Old Nov 13, 2006 | 06:27 PM
SuperBlue's Avatar
SuperBlue
I would check any and all fuses first.
Old Nov 13, 2006 | 07:00 PM
Don Tim's Avatar
Don Tim
Sorry all fuses have been checked user and under hood all good.
Old Nov 13, 2006 | 07:16 PM
Uzumati's Avatar
Uzumati
Which harness leg did you tie into?
Old Nov 13, 2006 | 07:17 PM
Pocket's Avatar
Pocket
If you've disconnected the T/C wiring harness and it still won't start, you may have fried the ECM. A direct 12v hit will kill it.
Old Nov 13, 2006 | 09:34 PM
Don Tim's Avatar
Don Tim
There are four on the fenderwell right below the brake master cylinder I tied into the gray one, As I said, Like an IDIOT I thought I was on the Vilot and Yellow pin 6 but it was red and yellow pin 10. Dohhhhhh
Old Nov 13, 2006 | 09:52 PM
Tenn01PSD350's Avatar
Tenn01PSD350
Disconnect both batteries for at least an hour. Turn on lights then, push brakes etc. to drain any capacitors etc. Then try again after restoring to normal wiring and see what happens. Normal WTS light etc and post results. Pay close attention to dash lights when doing so. A direct 12V can fry the PCM as previously mentioned.
Old Nov 13, 2006 | 10:12 PM
Uzumati's Avatar
Uzumati
What year and model is your truck. 01 4X4 pin 10 is the fuel pump but it is pink/black
Old Nov 13, 2006 | 10:24 PM
Don Tim's Avatar
Don Tim
2000 4x4 7.3 PSD
Old Nov 14, 2006 | 07:32 PM
Don Tim's Avatar
Don Tim
Gentleman! You were on the right track. after a lenghtly troubleshooting session I found that my transflow aux tank computer was not working either. It has nothing to do with the pcm so the direction was to find the power source for the Transflow (or in this case no power) an Viola there Fuse # 24 under the hood. Looked Ok but with the meter it was bad.
Thanks For the Leads
Tim in South Texas.
Old Nov 14, 2006 | 07:48 PM
Uzumati's Avatar
Uzumati
Fuse 24 under the hood is the PCM power relay fuse. It might be a good idea to power that aux tank from a different point. 10 is a mini and 20amp also its function is the Aux power socket so no chance of damaging something valuable like a PCM or IDM
