Aerostar Ford Aerostar
Battery Cable Mounting Bolt/Nut
Old Nov 13, 2006 | 06:13 PM
KimChee75's Avatar
KimChee75
I changed batteries in the Aero and evidently I stripped the bolt because the battery cable won't stay on the terminal. What size nut/bolt is the mounting one?
thanks in advance
Old Nov 13, 2006 | 08:42 PM
250K AS's Avatar
250K AS
Usually 1/2". Not sure of length...easy enough.
Old Nov 13, 2006 | 08:59 PM
Heavenword1's Avatar
Heavenword1
You can buy replacement bolts for battery cable ends at the auto parts store. But if you have the lead type cable ends, you're probably at more risk of having broken the U-shaped lead cable end than stripping that bolt. (Unless it's been corroded terribly.) I'd pull than end off and check for cracks in the lead. If that's broken, no amount of tightening the bolt is going to help--you'll need to replace the lead end.
Old Nov 13, 2006 | 10:13 PM
Bear River's Avatar
Bear River
Former ******
For durability, new cables are better than new ends. Replaceing just the ends allows corrosion to get inside the wires.
handyandy123
Nov 9, 2017 12:10 AM
fordinmudd
Feb 16, 2011 04:13 PM
handyandy123
Aug 27, 2010 04:44 PM
handyandy123
Aug 27, 2010 11:19 AM
rkane
Aug 1, 2006 10:38 AM
