2000 F150 lower ball joints
Old 11-12-2006, 07:40 PM
kcbillo1's Avatar
kcbillo1
kcbillo1 is offline
I need to replace the lower ball joints, failed inspection. I bought a Haynes manual as a guide but it says the lower control arm must be replaced, the ball joints are not serviceable. I have read posts about changing the lower ball joints, can they be replaced or do i need to replace the entire lower control arm?
Thanks Bill
Old 11-12-2006, 07:53 PM
ReAX's Avatar
ReAX
ReAX is offline
Moog k8695T is the lower balljoint for a 2000 F150 with a 4.6L. So you can buy the ball joint seperately.
Old 11-14-2006, 08:48 PM
yttocs's Avatar
yttocs
yttocs is offline
unless you have the ball joint press out tool you may need to remove the entire arm to put in a press.
bbsitum
1997 - 2003 F150
07-16-2015 05:12 PM
Moto7387
1997 - 2003 F150
11-13-2010 07:28 PM
jadams1978
1997 - 2003 F150
11-10-2006 12:41 PM
oldstylefseries
1997 - 2003 F150
09-26-2006 09:38 AM
MMARSS
1997 - 2003 F150
08-15-2006 06:51 PM
Quick Reply: 2000 F150 lower ball joints
