Sponsored by: Real Truck
Broken rear door latch
Old Nov 12, 2006 | 07:00 PM
mfpMAINeiac1's Avatar
mfpMAINeiac1
Hello, new member with a problem.
I just recently purchased a used (2002) F250 SD V10 XLT extended cab. The problem, rear door latch on drivers side is broken and will not release on bottom. Have purchased a new latch assembly but cannot get the door open to install the assembly.
any ideas or secrets to getting this darned bottom lastch to disengage?
Old Nov 12, 2006 | 07:08 PM
ReAX's Avatar
ReAX
Pull the plastic door panel off and look for a cable or rod. If you find one going to the lower latch, try pushing or pulling it until the door opens.
Old Nov 12, 2006 | 07:14 PM
mfpMAINeiac1
Yeah, been there done that. latch will not release, have tried manipulating with various tools to make it manually release to no avail. (latch is in an awkward location, BTW)
latch seems to be a two stage affair and will not realease that second stage (so to speak)
Old Nov 12, 2006 | 07:42 PM
ReAX's Avatar
ReAX
If you have released the first stage, push on the door while playing with the latch. Unless the second stage has pressure against it, it will not release.
Old Nov 12, 2006 | 07:48 PM
mfpMAINeiac1
yup, tried that too. any idea where i can find some kind of diagram or exploded view of the latch assembly so i can see what might be keeping it from disengaging?
12valveEx
Jan 6, 2016 05:17 PM
pwstroker69
Mar 17, 2015 08:37 AM
Trussonistephen
Feb 16, 2015 12:39 AM
69issofine
Jan 23, 2015 09:59 AM
cbasye
Jun 29, 2014 08:14 PM
