still having brake problems
Old Nov 12, 2006 | 04:39 AM
steve100's Avatar
steve100
this is a long ? so please bare with me. on my disk brake conv. i redrilled a hole in the flat bar conecting to the pedal.this lets the pedal hit the floor before the brakes in gage.tried a half inch spacer between the step bracket and the fire wall. same problem. should i try to adjust the rod coming on the m/c side of the booster? thanks for all the help.
Old Nov 12, 2006 | 05:25 AM
jowilker's Avatar
jowilker
Hi Steve, Did you use the existing pedel or a donor? I still run the orginal in mine. How far up the rod did you drill the hole?
The rod in question does effect the pressure applied to the brakes, but has nothing to do with the pedel adjustment. Two different adjustments.
With a little more feedback I hope we can work this out today for you.
John
Old Nov 12, 2006 | 06:51 AM
steve100's Avatar
steve100
hi i used the original pedal redrilled about 1/2 inch redrilled the hole in the pedal 3/4 down from original I mistakingly posted this in the wrong list. i meant to put it in the one for 66 and under though maybe you all can help I hope
Old Nov 12, 2006 | 07:15 AM
jowilker's Avatar
jowilker
Steve, You didn't specify a year so it will be ok to stay here.
If I read correctly you drilled two holes, I think you may have gone two far by doing two. You should be able to see where the hole needs to be, and drill another one up or down from where you did to correct the issue.
John
Old Nov 12, 2006 | 10:28 AM
steve100's Avatar
steve100
Thanks
Thanks for the help jowilker I redrilled again and things work great Thanks again for your help.
A H DEVELOPMENT
Oct 26, 2016 02:21 PM
blacktomato
Jan 10, 2008 02:14 PM
bizarro
Bronco II
Mar 30, 2005 10:02 AM
tonysquirrel
Jul 25, 2004 04:59 PM
