which engine
Old Nov 10, 2006 | 11:00 PM
Sqeejo's Avatar
Sqeejo
which engine
I have a 1999 Ford Explorer XL and I am about to start buying some performance parts for it. How Can I tell which engine it has in it. A SOHC 4.0 V6 or just a regular V6. Aparently there are two different ones? I'm not real smart when it comes to engines so please be gentle.
Jon
Old Nov 11, 2006 | 08:16 AM
steve(ill)'s Avatar
steve(ill)
i would think think there would be a sticker on the intake manifold, or maybe cast letters into the aluminum manifold.
Old Nov 11, 2006 | 09:19 AM
snowdog79's Avatar
snowdog79
The emisions decal on or near the fan shroud will tell you which engine it has. They also look quite different.
Old Nov 11, 2006 | 05:41 PM
Sqeejo's Avatar
Sqeejo
Unhappy okay I got the code
So where can I check the code to find out out. All it said was 4.0 and had a little serial number. I'm confused. The manifold just says 4.0 EFI.
Old Nov 11, 2006 | 07:58 PM
Steina's Avatar
Steina
CO River Rat
If you're close to a dealer, run your VIN by the service department and hopefully they'll help you; one of the digits in the VIN will tell you whether it's a pushrod or SOHC V6.
Steve
Old Nov 12, 2006 | 06:19 PM
Nocturnall's Avatar
Nocturnall
There should be a big plastic shroud right on top of the motor that says SOHC on the front of it. If you have a thing showing on the top running vertically with tunnels coming off the side down into the engine and it says efi or ohv on it then you have the 4.0 OHV engine.
Old Nov 12, 2006 | 06:29 PM
maa139's Avatar
maa139
Steve
The 8th digit is the engine.
Old Nov 12, 2006 | 07:36 PM
Steina's Avatar
Steina
CO River Rat
Thanks - couldn't remember which one it was.
Steve
Old Nov 13, 2006 | 11:18 AM
Sqeejo's Avatar
Sqeejo
Thanks for the help guys. It appears by the appearance, (It does show the down tubes on the manifold) and by the VIN code that it is the OHV. I appreciate all the information. It has been very useful.
