Sponsored by: Real Truck
2002 F 250 XLT bouncing
Old Nov 10, 2006 | 08:17 AM
02F250XLT's Avatar
02F250XLT
Exclamation 2002 F 250 XLT bouncing
when i drive my truck between 40 and 50 miles per hour, the rear end feels like its bouncing, its real bad. at times i cant even talk i was told by ford its normal but, there is no way
Old Nov 10, 2006 | 08:19 AM
Pocket's Avatar
Pocket
Do you feel it only in the rear end, or in the drivetrain??
If it's in the rear, then more than likely it's a tire balance issue.
If it's in the drivetrain, it could be a u-joint failing, an unbalanced driveshaft, or even a flywheel weight has fallen off.
Old Nov 10, 2006 | 08:22 AM
2006PSDSD's Avatar
2006PSDSD
Check your rear shocks as well, they can make your rear end vibrate if your tires are out of balance, if they're blown out.
DeeDubz
6.7L Power Stroke Diesel
24
Jan 9, 2015 08:33 AM
jimbo285
Jun 27, 2012 09:38 AM
Milwaukee1979F150
Dec 1, 2009 09:30 PM
northwestsuperduty
Sep 8, 2007 11:49 PM
05f250fx4
Jun 22, 2006 06:58 PM
