the front end of my 2004 f250 will start to bounce when i am going between 60km/h and 70km/h i was just woundering if this is normal or if the mechanic is lying to me
No, you have an issue that you need to look at. My SD is smooth as fast as I care to go, well over 70mph. First thing I would try is swapping out the shocks for bilstiens, even if they don't fix the bounce it will make for a better ride. Second, I would play musical tires until you find one or two that is out of round or warped.
You might also want to have them road force balanced. I am not completely sure of how it works, but it appears to put a load on the tires during balancing so it can account for some deformation.
Now I'm wondering if thats what it causing my wicked front end vib at 60-70mph.. I thought it was my driveline not shimmed right.. Grr tires are pain in the rear!
It could also be the alignment. with the lift, you need an intelligent mechanic to arrange the caster, camber and toe-in. Stock spec's don't work, and guess work isn't much better. A minor bit off amplifies at speed, then add an out of round tire and you end up with a very difficult time diagnosing your problem. However, check the tires out first.
I'm pretty sure alignment is good.. She drives straight.. Let go of the wheel and she doesn't move.. It just shakes the steering wheel and gets worse at higher speeds.. I just figured it for drive line.. I did a work over this last weekend.. Check all the wheel joints, knuckles, rods, bolts, everything.. Not a single thing loose.. She was aligned after the install for the lift. Ford did the install but hell its worth a check
