Sponsored by: Real Truck
Cold Weather Prep
Old Nov 9, 2006 | 11:31 AM
Ken Bailey's Avatar
Ken Bailey
Cold Weather Prep
I have a 2006 F250 PSD Lariet. Just found out I'm being transfered to S/W Wyoming. I will be there from Jan. until May. Is there any precautions or prep I need to do with my truck for the cold weather-block heater stuff like that.
Old Nov 9, 2006 | 05:14 PM
ReAX's Avatar
ReAX
I have never been anywhere that cold, but battery trickle charger, block heater and good anti freeze come to mind. Cold batteries have a harder time starting an engine, the charger will help with that.
Old Nov 9, 2006 | 05:43 PM
jim henderson's Avatar
jim henderson
you may want to consider a synthetic engine oil and maybe differential fluid.
Or you may want to use a 5W20 or even 0Wxx oil if you can find it. Don't know if dino comes this thin, but syn does.
Also get some windshield defroster spray and an ice scraper. Kick up the antifreeze type window washer fluid. Air up your tires.
Put some silicone lubricant on the rubber weather stripping around the doors so the doors don't stick.
Top up the water in your battery and keep it charged.
Spray your lock cylinders with graphite. Use NOTHING with GREASE or oil or the locks will stick.
Good Luck,
Jim Henderson
Old Nov 9, 2006 | 06:07 PM
ohboy44's Avatar
ohboy44
Block heater and battery heaters, plug them in and forget about it.
Old Nov 9, 2006 | 06:39 PM
BareBones's Avatar
BareBones
You'll learn this soon enough, but there are things called "winter wipers" , which are windshield wipers on which the support structure on the wiper are covered by a rubber boot. What frequently happens is that when these areas fill with snow/ice the blade loses it flexiblity - and you lose your visibility...... You won'd be able to find them where you are, but ask around once you arrive.
Old Nov 9, 2006 | 06:48 PM
ReAX's Avatar
ReAX
I forgot about those. Anco carries them, if you can find someone willing to order them any anco dealer can get it.
Old Nov 9, 2006 | 11:00 PM
bneafus's Avatar
bneafus
How about cold fronts...Yoou know the radiator blankets or blockers?? I've used them on gassers..Anyone use them on the 6.0's??
Old Nov 10, 2006 | 07:36 AM
Super08's Avatar
Super08
I just use a piece of cardboard with slits cut in it placed between the grill and the rad. Cost is free and I get a new one every winter.
Old Nov 10, 2006 | 08:12 AM
02F250XLT's Avatar
02F250XLT
another good investment is a remote car starter, unless you a garaging yours, but in most cases you wont fit in a garage, so the pre heating is nice
Old Nov 10, 2006 | 11:32 PM
Musicman250's Avatar
Musicman250
Thick gloves, a heavy jacket, -40c snow boots, a snow shovel and 6 bags of traction sand in the bed over the back axle.
That what I've been hauling since the first snow dump, a few weeks ago.
