quick ATS question
Old Nov 9, 2006 | 07:53 PM
crack's Avatar
crack
running around 20psi isnt overboosting is it?
Old Nov 9, 2006 | 08:01 PM
Uzumati's Avatar
Uzumati
No the pcm considers 24psi overboost and will defuel
Old Nov 9, 2006 | 08:11 PM
crack's Avatar
crack
well, I dunno whats up, I thought the boost would drop a couple psi but not over 5, and I expected the EGTs to drop. I might go over all the connections again.
Old Nov 10, 2006 | 12:25 AM
ryaneverk2's Avatar
ryaneverk2
I think you still have a boost leak.
When I did the ATS housing, I remembered the big o-ring as I spotted it easily. However, the o-ring that goes between the compressor outlet and the y-pipe that splits between the intercooler pipes, I forgot. It was stuck in the old stock housing, and as I was stashing that away after finishing up, I saw the o-ring staring me in the face.
Maybe you left that one like I did.
Hope you find the problem...
Old Nov 10, 2006 | 12:47 AM
crack's Avatar
crack
I made sure I gotthat one, and I remember seeing the big one when I was putting the ATS housing on...17ft lbs didnt seem like much to torque that down to....tomorrow morning Ill rip it all apart I guess....not the funnest thing
Old Nov 10, 2006 | 11:07 AM
crack's Avatar
crack
ok, I just started my truck up, its about -3 deg. celcius. it sounds different, and its blowing a little bit of smoke when idling, wich it never did before....
Old Nov 12, 2006 | 02:01 PM
crack's Avatar
crack
undid and re tightend all clamps from the housing to the intercooler. still the same. I guess Ill have to take the housing off and check it all out. maybe ill borrow my buddys superchip and see if I pull any codes.
Old Nov 12, 2006 | 02:19 PM
jtharvey's Avatar
jtharvey
Did you pull the turbo to install the housing, or do it on the truck? If you pulled it, there could be a few things causing it.
Old Nov 12, 2006 | 02:20 PM
crack's Avatar
crack
did it on the truck.
Old Nov 12, 2006 | 02:36 PM
jtharvey's Avatar
jtharvey
Well, that eliminates that possibility. Looks like you're going to need to pull it apart and check for anything that looks abnormal. I'm lost as to what it might be.
Old Nov 12, 2006 | 03:22 PM
crack's Avatar
crack
hmm, yea...I should have taken the housing off when I had all the pipes off. dad has a ****** in the shop right now..hopefully I can poke my truck in ther for a couple hours soon.
Old Nov 18, 2006 | 07:07 PM
BigRedGettinFaster's Avatar
BigRedGettinFaster
so what ever happened to this guys problem?
Old Nov 19, 2006 | 07:54 AM
  #28
Orezona's Avatar
Orezona
Bump, I'm also interested....
