the Halesensors are on the back of the t/c case, a 10mm bold holds each, plastic shells so be carefull, just take them out wipe off the crud and filings, reinstall
Just checked the code and I believe a D4 is a 3.73 Limited Slip diff.
So I have Limited Slip..
I experience a bit of a problem when testing to see if the problem still exists after changing the TC fluid and adding Ford Friction Modifier to the rear.
The problem is much less and maybe will work itself out.
Will see when it rains again.
If still there,then I'll clean the Halesensors.
