Grill
Old Nov 8, 2006 | 08:54 AM
bucks77ford's Avatar
bucks77ford
Grill
I looking at buying this grill, but I am wondering what those three bottom holes are. I have looked at other grills and I have seen only one hole. Are those three holes factory? Thanks.
Old Nov 8, 2006 | 08:57 AM
pickupbuilder's Avatar
pickupbuilder
I have a 74 parts truck that has the same three holes in it and they appear to be factory. They bolt the grill to the cowl support. This truck is a two wheel drive. I don't know if that makes any difference.
Old Nov 8, 2006 | 09:11 AM
bucks77ford
Thanks for the repy. i guess it probably wouldn't matter since those holes would be covered up by the front bumper. I just wanted to make sure those are factory holes and not something somone had drilled out.
Old Nov 8, 2006 | 09:32 AM
1975Ford's Avatar
1975Ford
Pickupbuilder, welcome to FTE.
The two outer bottom holes on grille bolts to the two outer fenders.
The middle hole bolts on grille, bolts to a L-shaped bracket that mounts to the radiator support.
Old Nov 8, 2006 | 09:56 AM
bucks77ford
Thanks for the reply.
