Strange problem with 03 expy
Old Nov 8, 2006 | 07:37 AM
thavngr98's Avatar
thavngr98
Question Strange problem with 03 expy
I had my backup sensors fixed by my dealership last week and on the way out I filled up the truck at a gas station that I've never been to. On my way home I noticed that when the truck is in first gear it has a very quick hesitation. This only happens mid gear not when shifting. I thought maybe I filled up the tank with some bad gas. Well now I have a new tank of gas and the same thing is happening. It only happens once or twice a day and 99% of the time it happens when giving gas and the truck is in first very rarely second gear. To explain what it feels like it, it feels like the engine is getting starved of gas for a split second. Does any one have an idea what may be causing this? My next guess is a fuel filter but I would think it would be happening all the time and it would not be rare as its happening
Old Nov 8, 2006 | 12:47 PM
bridge's Avatar
bridge
Sick 'n Tired
Eliminate the fuel filter as the problem by replacing it if it has more than 15K miles on it. It's cheap and easy.
Old Nov 8, 2006 | 03:51 PM
aagitch's Avatar
aagitch
If it's not the fuel filter, take the expy out on the highway and drive it real hard from a stop or slow speed. Maybe you can get an engine light and then a code. Could be a mis.
Old Nov 10, 2006 | 01:24 PM
bumparker's Avatar
bumparker
I had a similar problem and it turned out to be an intermittant miss due to a COP miss/short. I will bet you that it is a COP that is acting up. Unfortunately, if you're not getting a CEL (I didn't) there won't be a stored code. You'll have to take it to someone that has diagnostic equipment to determine which COP is acting up. How many miles do you have? If more than 60,000 you probably need to replace the plugs and the insulators anyway (I know Ford recommends 100,000 miles) but the COPs and insulators are very problematic on this engine. I've had to have 2 replaced within the first 70K.
Old Nov 12, 2006 | 06:16 PM
thavngr98's Avatar
thavngr98
Ok Im horrible with acronyms. What is COP and what is CEL.
My truck has 47,000 miles
Old Nov 12, 2006 | 06:24 PM
thavngr98's Avatar
thavngr98
ahh COP = Coil on Plug
Thanks google!
Old Nov 12, 2006 | 08:16 PM
aagitch's Avatar
aagitch
CEL=Check Engine Light
Old Nov 20, 2006 | 08:17 PM
thavngr98's Avatar
thavngr98
Problem was my number 4 cylinder Coil. Replaced it today and the truck runs great
Juanimeus
20
Nov 13, 2014 10:27 PM
timmb
Dec 9, 2013 04:54 PM
attroll
50
May 23, 2006 11:38 PM
JBronco
1978 - 1996 Big Bronco
Apr 23, 2005 07:38 PM
N_fini_T
21
Mar 3, 2003 09:54 AM
