Build date?
Old Nov 6, 2006 | 09:56 PM
bismic's Avatar
bismic
Build date?
The sticker on the drivers side of the engine has the following number under the VIN number - 4689 /9430 /2. Does this tell the build date? If not, where can I find it? Sorry to repeat a previous question, but I could not find the previous thread.
mic
Old Nov 6, 2006 | 10:13 PM
blackhat620's Avatar
blackhat620
bismic,
Yellow sticker on the PCM which is on the Drivers side valve cover toward the firewall. This is the engine build date.
Drivers side B pillar certification sticker, this is truck manufacture date.
Hope this helps
Old Nov 6, 2006 | 10:50 PM
bismic's Avatar
bismic
Thanks for the reply. I believe I found it. The yellow sticker has the Engine build in Indianapolis. The number below this was EN200 260406 6801872. I assume this means an April 26 2006 build date (middle number). The pillar states a manufacture date of May 2006.
mic
Old Nov 6, 2006 | 11:12 PM
blackhat620
Originally Posted by bismic
Thanks for the reply. I believe I found it. The yellow sticker has the Engine build in Indianapolis. The number below this was EN200 260406 6801872. I assume this means an April 26 2006 build date (middle number). The pillar states a manufacture date of May 2006. mic
You are correct
