Ford 351 W
Old Nov 11, 2006 | 03:23 PM
  #31
peepinu's Avatar
peepinu
Bsddad 457, I already have an edlebrock 600cfm carb with a one inch aluminum swirl plate over an edlebrock performer manifold and msd6 ignition with headers and performance exhaustas i told conaski it seems real lacking at cruising when i pull hills it seems to fall off. So i am probably looking at either a cam kit or a cam and head change. I guess i am trying to get from you guys is if i do that will i see significant gains(i don't mean smokem off the line power or chirp them in third. I would just like to step on the peddle and feel something in response that i don' get now.
Old Nov 11, 2006 | 03:27 PM
  #32
peepinu's Avatar
peepinu
By the way again all you guys have been really great, thanks conaski for getting this all started. It is nice to find a place you can go and get good field advice, unlike the reponse i got from summit and TCI when i asked there tech support. You were right on the money. So these e5 heads are pretty worthless, i don't want to invest in re-working them i would feel better about just investing in a set of new heads.
Old Nov 11, 2006 | 03:43 PM
  #33
peepinu's Avatar
peepinu
Conanski send something about explorer gt40 heads, what year
Old Nov 11, 2006 | 08:51 PM
  #34
baddad457's Avatar
baddad457
Do you know for certain the secondaries are opening on the carb? I'm not a fan of the Edlebrock carbs, but all I've read posted about them, they leave a lot on the table when compared to a similar sized Holley. A change in manifolds to an RPM would help too. The std Performer isn't much more than a copy of the stock factory 351W intake. As for the MSD, I don't know what you had before, but if you already had a Durspark setup, the MSD was a waste of dollars. You might also try advancing the timing and checking to see that it's advanced fully at about 3,000 rpms. Your initial timing should be about 12* BTDC. Work with the carb and timing before spending money on the heads. Even my 95 E150 van pulls like a freight train when you nail the gas and it's 351W is completely stock, ecepting the K&N filter element and the intake silencer removed. Factory HP rating for it is only 210 hp.
Old Nov 11, 2006 | 08:52 PM
  #35
Conanski's Avatar
Conanski
No not entirely. The E5 and E7 heads are very close actually with the same valves and combustion chamber shape and size. The air injection hump in the exhaust port on the E6 heads is massive, but it's just a small blemish on the E5 and E7 heads by comparison, so these heads will perform very similarly. A cam will make a significant improvement on this motor, it should easily maintain hwy speed with it, and it's definitely the best bang for your bucks at under $200.
Old Nov 12, 2006 | 11:21 AM
  #36
peepinu's Avatar
peepinu
lets talk cam then what type of lift and duration. I saw at summit, comp cams extreme truck cam. If i read you right i want a cam performing in that 1500-5000 rpm range as at cruise i am running about 2500-2600 rpms
Old Nov 12, 2006 | 09:45 PM
  #37
fordtruck257's Avatar
fordtruck257
camshaft
i have a cam with a lift of .554 and .558 lift i cant remember the exact duration but its radical as **** its the comp cam extremem energy series
Old Nov 13, 2006 | 08:38 AM
  #38
P51D Mustang's Avatar
P51D Mustang
Originally Posted by baddad457
According to what Conanski posted , you've got E5AE heads. Chambers are big at 67-70 cc's. Swapping to a set of 64 cc heads will raise the comp ratio a half point, to 9.0 to 1, if you've got an 8.5 to 1 ratio. .
I'm not so sure about those chamber volume numbers. I only had to mill a set of E5AE heads .020 to get 57cc's. That's what they measure now, so I don't know what they measured originally, but if they were 67cc to start with, I don't think you could loose 10cc's with only a .020 mill? I have a set of stock E6SE heads out in the shop, and IIRC, they also measure smaller chamber volumes than some of the books list.
Old Nov 13, 2006 | 09:08 AM
  #39
Conanski's Avatar
Conanski
I'll second that. The books are good but the info is not always 100% accurate. My E6's measured 65cc after I unshrowded the intake valves.
Old Nov 13, 2006 | 09:09 AM
  #40
peepinu's Avatar
peepinu
You guys sure k nowalot more about this than i do, i looked at a set of world jr heads they were 180cc with 58cc comb chamber. I have been looking on ebay about heads i see some pretty good deals. One other question that baddad457 brought up about total advance, how do i find out what the total advance should be for my pu and at what rpm.Let me throw this out to all of you, with the heads i have now if i put a cam in will it be cmpatible with everything. Looking at one of those comp extreme cams with 260/272 duration and about 484/493 lift. i want all of you to know that i am a real rookie at this but have always been interested in doing things like this. Never was a real gear head but you have sparked a real interest for me. Thanks again guys.
Old Nov 13, 2006 | 09:35 AM
  #41
Kemicalburns's Avatar
Kemicalburns
call compcams , there tech support is far better then summits. just explain what your running and where your going with your rig (plans). they can make a better call on what works for ya. also what plugs and wires you running. make sure plug wire 7 & 8 are not crossed and touching. this will cause a power loss for sure as well.
Old Nov 13, 2006 | 04:40 PM
  #42
fordtruck257
watttt??????!!!!
thats y they r after market go on summit and look at them for a 351 windsor cast iron heads i been building motor for yrs and u wanted advice so i gave it and dont question my information
Old Nov 13, 2006 | 04:50 PM
  #43
baddad457's Avatar
baddad457
Wouldn't be the first time the books were wrong, but seems they all list those heads as having 70cc chambers. I milled my Canfields .060 and got 57 ccs.
Old Nov 13, 2006 | 04:53 PM
  #44
fordtruck257
so r u saying that mine arn't 58 cc cuz u can spend the 900 dollars and check for urself
Old Nov 13, 2006 | 05:07 PM
  #45
baddad457's Avatar
baddad457
HUH?
