Brake bleeding problem
Old Nov 6, 2006 | 12:55 PM
wrecksracer's Avatar
wrecksracer
I am having a problem bleeding my brakes on a 04 f-150. I took it to a pretty good mechanic. He told me that there is air trapped in the abs somewhere and that ford has a special tool that can get the air out. Also, I am getting an obd2 reading, P0506, idle air control system, rpm lower than expected.
Old Nov 6, 2006 | 01:13 PM
ohboy44's Avatar
ohboy44
What was changed to get air in the system?
If you have air in the ABS unit you will need a NGS+/WDS/IDS to do a service bleed. It activates the solenoids and valves in the ABS unit to get the air out.
Old Nov 6, 2006 | 01:53 PM
wrecksracer
I took a good hit broadside in the right rear wheel. Broke my axle in half. I have pieced it back together rather successfully, just a few bugs. I guess its off to the dealer. Thanks for the help
Old Nov 6, 2006 | 07:45 PM
ohboy44's Avatar
ohboy44
If you didn't replace the ABS unit there is no need to do the service bleed.
Just bleed out all 4 wheels good.
These trucks have a soft brake pedal to start with. In fact if you push hard enough you can put it to the floor.
DLGries
1983 - 2012 Ranger & B-Series
Mar 22, 2024 08:02 PM
Headviking
Jul 31, 2011 12:27 PM
imlowr2
23
Nov 24, 2007 10:55 PM
truckman01
Jul 22, 2007 03:25 AM
fatboy95
May 25, 2005 03:05 PM
