Checking Trans Fluid
Old Nov 6, 2006 | 10:33 AM
monty0's Avatar
monty0
Should the transmission fluid level be checked with the motor running? Or can it be checked either motor on or off? Thanks in advance.
Old Nov 6, 2006 | 10:51 AM
blackhat620's Avatar
blackhat620
monty0,
Checked with the engine running, at normal operating temperature with vehicle parked on level ground.
Hope this helps
Old Nov 6, 2006 | 12:05 PM
raptor131's Avatar
raptor131
drive the truck about 9 miles and then check it with the motor running.
reason transmission fluid expands as it heats up , and it has to be running as when it is not all the fluid is in the pan, with it running several quarts are circulating inside the tranny which reduces the static amount of fluid on the stick
Old Nov 6, 2006 | 09:29 PM
monty0's Avatar
monty0
Thanks for answering my question.
Schlominator
Mar 9, 2014 10:44 AM
UaVaj
Dec 2, 2010 04:11 PM
Rockyray1
2004 - 2008 F150
Sep 3, 2009 06:10 AM
oahuobx
Aug 17, 2006 04:01 PM
d0n_3d
1983 - 2012 Ranger & B-Series
Sep 9, 2003 02:50 PM
