Power steering gone?!
Old Nov 6, 2006 | 07:17 AM
rudyexp's Avatar
rudyexp
Hello All!
This morning I started my 98 Explorer, and I thought I heard something, radio was on. But the battery light is on, and no power steering at all. I also hear a clank click when it moves reverse or forward. Kinda of hard to tell, I'm in a tight spot, only have about 8 feet to move, can't make my hard right turn out of my drive like I use to. Any ideas?!
Thanks
Rudy
Old Nov 6, 2006 | 08:24 AM
marragtop's Avatar
marragtop
Start by checking to make sure the serpentine belt is still on.
Old Nov 6, 2006 | 08:46 AM
rudyexp's Avatar
rudyexp
Hi Marragtop!
Thanks for the quick reply! Will the enging run right if the serpintine belt is broke? I always thought if that goes, nothing will work, including the engine running smooth. What does that belt affect?
Also, I did check the power steering fluid, it's full. I was thinking if the pump went, I should have a fluid underneith the truck, but everything was dry.
Thanks again!
Rudy
Old Nov 6, 2006 | 08:54 AM
marragtop's Avatar
marragtop
If the belt breaks, the engine will still run, but it will overheat since it won't be pumping any water. Also, the CEL will come on. Checking the belt will only take you less than a minute. Just pop the hood and take a look at it.
Old Nov 6, 2006 | 04:44 PM
mountaineer man's Avatar
mountaineer man
sounds like a belt to me
Old Nov 6, 2006 | 10:35 PM
rudyexp's Avatar
rudyexp
Smile
Hi All!
So it was the belt, the belt didn't break, but the tension pulley did break. The spring is still on but the pully unit and the cover of the spring broke off. So tomorrow I'm getting anohter tension pully and a new belt. Takin the day off wednesday to replace this, since I can't drive it, or have the money to have it towed.
The next big question is, how hard is this. I can change oil, replace brake pads, etc, how much of a challange is this going to be?
Thanks for all your help!
Rudy
Old Nov 7, 2006 | 04:51 AM
marragtop's Avatar
marragtop
I'm not sure which motor (6 or 8)you have, but it shouldn't be a big deal. Hopefully, you have the belt routing diagram under the hood that you can reference when you put the new belt on.
Old Nov 7, 2006 | 05:23 AM
K2JJB's Avatar
K2JJB
I was able to replace the belt on the my v8 in about 10 minutes (real easy job, just be sure you get the routing of the belt correct)... not sure how hard the tensioner is to replace in these vehicles, but the one I did on my wife's pickup (non Ford) was a total of removing the belt, removing the bolt that held the tensioner, replace the part and bolt, reinstall the belt (in her case I did not replace the belt as it was pretty new) - total time was under 30 minutes.
Old Nov 7, 2006 | 06:46 AM
rudyexp's Avatar
rudyexp
Thanks! Sounds like I won't waste my whole day off with this thing. Thanks again for all the help!!
Rudy
Davehart24
Sep 27, 2014 01:52 PM
jccapri
Jan 16, 2014 03:33 AM
Speedjester
Dec 8, 2010 11:22 PM
1976F250HiBoy
Nov 26, 2009 10:30 PM
SpeedRebel09
Feb 19, 2009 07:55 AM
