Toyota Power Steering Conversion
Old Apr 5, 2002 | 09:17 AM
skeleton's Avatar
skeleton
What all should I be salvaging from the 1979-1985 Toyota 4X4 for the P/S conversion for a 1951 ford f-1? Obviously the power steering box, but what else do I need?
Old Apr 5, 2002 | 11:00 AM
55FordLover's Avatar
55FordLover
The lines, pump (or go with anyone u like), the resovoir...the brackets for the pump (your choice) ....i got everything from the steering linkage shaft to the frame....that way u wont be missing anything....
James
55 Ford F100 (for sale)
54 Ford F100 302/AOD soon :-)
Old Apr 5, 2002 | 07:11 PM
jaye's Avatar
jaye
You are definitly going to need the power steering unit and the hoses. You can get the power steering pump for what ever pump goes with your engine. You are also going to need a bracket to mount the unit on your frame. If you use the pitman arm off the toyota you are going to have to weld the ball off your original pitman arm on it or you can bye one from Bob/s F-100, he also sells the bracket to mount the unit on the frame.
Old Apr 5, 2002 | 11:07 PM
lshort's Avatar
lshort
Make sure to get the hoses I tried to get a new pressure hose made to
mate to my ford pump and never did find the fitting to screw in to the pressure side of the pump.I finally cut the end off the toyota hose and welded it to the ford hose.Does anyone know the size and discription of the pressure fitting?
Old Apr 6, 2002 | 06:40 PM
jaye's Avatar
jaye
I had no problem getting one for my 302, I just changed pumps and had to get another end because the pumps were different. Just go to a shop that makes hydrolic hoses or A/C hoses. I only paid $5 bucks for cutting, fitting and labor. However you have to be careful with the toyota hose because it is steel braded on the inside.
Old Apr 6, 2002 | 09:12 PM
55FordLover
thanks for that info bro....i was taking out my original gear box today and going to order the bracket from Mid-Fifty...man was it hard to get out after 48yrs of tightening...
James
55 Ford 223/3 spd (For Sale)
54 Ford 302/AOD soon
Old Apr 10, 2002 | 02:25 PM
markd's Avatar
markd
I believe the pressure fitting is 17mm inverted flare. I never did find out the description of the return fitting. Make sure you get it with a junkyard box or aftermarket hose set.
Old Apr 11, 2002 | 04:35 PM
skeleton's Avatar
skeleton
Jaye~
Did you fab your own Pitman arm? If yes, how difficult?
Old Apr 11, 2002 | 07:06 PM
dongc1's Avatar
dongc1
>Jaye~
If you have access to a cnc mill, I have a program to cut a arm from 5/8" plate. It cuts a keyhole in the top and a hole in the bottom to tap. Tap the hole and screw in a replacement ball that is available from Sacremento ford. Clamp the Toyota arm down on the mill and it then cuts the top part of the Toyota arm off to fit the keyhole in the steel. Press the Toyota part into the steel arm, Tig weld around it and your ready to go.
If you want the programs, send me a e-mail and I will send them to you.
Old Apr 11, 2002 | 08:01 PM
jaye's Avatar
jaye
I purchased my pitman arm from Bob's F-100, which appears to be a toyota arm with a 55 ball welded on it.
Old Apr 11, 2002 | 09:35 PM
55FordLover
So I assume that the 1980-85 pitman arm ball does not fit the original. Dag man, more lot than the average. Using a Ford Galaxy 500 steering column and have to motify the end of shaft linkage to the P/S box. Waste of money to buy the u-joint when you just grind a little and use the linkage of toyotas. Save about $80 bucks foreal. That is why I say get everything from the box to the steering wheel.
James
54 Ford F100 (302/AOD within 2-1/2wks)
Old Apr 12, 2002 | 09:26 AM
skeleton's Avatar
skeleton
dongc1~
Sound good! My e-mail address is skele9(No Email Addresses In Posts!). Thanks.
Old Apr 12, 2002 | 02:06 PM
darkhorse54's Avatar
darkhorse54
Mid Fifty sells a better pitman arm then Bobs F-100, it's $95.00 and no core charge.
Old Jun 26, 2002 | 01:07 AM
visalia6439's Avatar
visalia6439
Post Toyota Power Steering Conversion
For what it's worth... I had a Toyota PS unit installed in my '59. Works great! Save EVERYTHING from your Toyota unit. Murphy's Law: the one thing you don't retain is the one thing you'll be missing and it'll be the toughest and most expensive to get!
Enjoy the PS unit!!!
DS
Old Jun 26, 2002 | 09:48 AM
hirschi's Avatar
hirschi
Make sure to get the little brass fittings that go inside the toyota P/S box. They are the seats for the hose flares. If you don't have them it will not seat and they are not easy to get. Bob's F-100 has them for $10 each!!!!
The toyota shop only sales them in the re-build kit for the pump. I was lucky enough to find someone who took it out and sold it to me separate for $3.
I was sittin pretty after that. Just don't loose them. It's better that way.
Good luck. (I just wanted to make sure this point is clear. Don't know if anyone else had this problem.)
James
