Recharging Kn Filter
Old Nov 5, 2006 | 09:47 AM
blackandsilver94's Avatar
blackandsilver94
Question Recharging Kn Filter
Well its time to clean my air filter. Ive heard and read about the oil that is used, and if you use to much it could damage internal parts of your motor. Knowing me I would probadly put too much. So i was wondering if i could just run it dry?(with no oil). Or should i just go to Autozone and spend the $7.50 for a regular filter?
Old Nov 5, 2006 | 11:22 AM
Unfairlane62's Avatar
Unfairlane62
I definately would'nt run it dry as its mainly the oil that makes the dust and grit stick to the filter, you can buy the recharge kit and just follow the instructions its quite simple, you get a choice of oil you can either spray it or just run it down the filter. I use the spray one. hope this helps, rick
Old Nov 5, 2006 | 12:05 PM
wendell borror's Avatar
wendell borror
"For the love of all things holly". don't run it dry !!! Thats like haveing no filter at all basically. I think the over oiling issue has been over stated. I've oiled many a k&n filter, and I'm no expert at it and have never had a problem, as stated, just follow the instructions, it's not hard. There should be no white showing, it all should be red, just don't saturate it. It would be better to go an get a paper filter, than run the k&n dry, like I say , the issue has been over stated, have a crack at it, it's really not hard.
linus72
Jun 15, 2012 12:06 PM
guntruck
Apr 14, 2012 11:20 AM
shipfitter1966
Jun 10, 2006 07:56 PM
justdan
Oil & Lubrication
37
Dec 20, 2004 09:01 PM
MichiganMarc
Jul 5, 2004 06:28 PM
