Block question
Old Nov 4, 2006 | 07:29 PM
1970Custom's Avatar
1970Custom
Block question
did the 7.3's block ever change design? My dad has a '96 and chipped it, now its needing better gearing and was thinking about the newer 6spd in the next generation PSDs.
Thanks
Old Nov 5, 2006 | 06:59 AM
tjbeggs's Avatar
tjbeggs
no the block never changed the 6sp will bolt up but you will need a superduty t-case. i believe the crossmember will need to be relocated and the drive shafts will need to be remade since they will be different length. and the t-cases fromt he superduties are elctronic actuated not lever so you will need to wire that up. also from what i have read the 6 sp has less desirable gear spacing. and if thats not true all the 6 sp is is the 5 speed with a creeper gear. it not impossible some have done it. what about different gears in the differentials?
Old Nov 5, 2006 | 08:00 AM
barebackjake's Avatar
barebackjake
its alot of time and money, you either need to make some floor pan mods or put a body lift on the truck. you can get the full manual tcase also. for all the money that is spent you can get a us gear unit and have a 10speed
