head bolt sealer
Old Nov 4, 2006 | 08:51 AM
propane32's Avatar
propane32
head bolt sealer
help ,what is the best sealer to use on head bolt where you have water jacket to head bolt crack ,thanks clyde
Old Nov 4, 2006 | 10:10 AM
ALBUQ F-1's Avatar
ALBUQ F-1
I assume you are talking about a Flathead V8? If it is leaking water up along the bolt, I think your crack is a pretty bad one. Your best bet may be to run some Alumiseal in the cooling system to plug it. There are other products but that seems to be the least obnoxious IMO. I doubt you could seal it "from the top" because there is always going to be a place where there is no surface to seal against (right around the bolt).
Old Nov 4, 2006 | 10:28 AM
propane32's Avatar
propane32
head bolts
i am sorry i didnt make my self clear , we found small cracks from waterjacket to head bolt was advised to put some sealer on bolts when i reassemble engine to be on safe side i dont think it leaked originally before i tore engine apart, yes its flathead v8 239, thanks clyde
Old Nov 4, 2006 | 11:05 AM
DonMckay's Avatar
DonMckay
Just use a good anti sieze compound such as Copper Coat. You apply it to the threads of the Head bolts and also to the under side of the bolt head. I think this is what they are referring to.
Don
Old Nov 4, 2006 | 11:35 AM
mtflat's Avatar
mtflat
Like Don, I use Copper Coat as a preventative whether I have those cracks or not - think it's made by Permatex. I've also used the white teflon thread sealer by Permatex and they both work equally well.
72CC428
Aug 6, 2016 05:37 AM
miller53
Dec 12, 2014 11:49 AM
pete60hill
Mar 13, 2014 04:09 PM
rlandrum
Sep 29, 2011 01:42 PM
familyman65
Flathead V8 & Flathead 6
Jul 2, 2009 06:58 PM
