Check Engine Light
Old Nov 3, 2006 | 06:34 PM
jecp's Avatar
jecp
Check Engine Light
OK, I give up. First the speedo starts acting flaky, now the check engine light comes on. I disconnected the battery a week ago when it first came on, and it was out for seven days. This morning, it came on again. Is there anyway to pull the code(s) without a scanner? BTW, this all started when I hit 100K.
Thanks for any and all advice.
Old Nov 3, 2006 | 06:39 PM
BearMan54's Avatar
BearMan54
Post Codes
If you got an AutoZone close by, they will read your computer for free....
Old Nov 3, 2006 | 06:42 PM
jecp's Avatar
jecp
Thanks. Question, can they be trusted, meaning if it is an o2 sensor that costs 50 bucks, will they tell me it is that plus a $100 flangele valve?
Old Nov 3, 2006 | 06:51 PM
projectSHO89's Avatar
projectSHO89
Just have them scan the computer. Don't let them even try to diagnose it.
Just write down any codes and come back here and do some research.
Steve
Old Nov 3, 2006 | 07:44 PM
jecp's Avatar
jecp
Ok, got the code. P0125, coolant temp no high enough to enter closed loop operation. Low coolant, bad thermostat? Truck has always run cool in the colder weather, but it has great heat. Suggestions?
Old Nov 3, 2006 | 09:40 PM
Rockledge's Avatar
Rockledge
I got the same code two winters ago. I replaced the T-stat and ECT sensor and haven't had a problem since.
