transmission cooler?
Old Nov 3, 2006 | 08:33 AM
lossscause's Avatar
lossscause
97 F350 RC LB 4X4 7.3L E40D
I know these trucks have an external cooler, but do they also have an internal cooler in the radiator? I am replaceing the trans and i will put a new external cooler on it, but do i need to have the thing flushed?
Thanks
Old Nov 3, 2006 | 08:52 AM
DaBigTow's Avatar
DaBigTow
yes, there's an internal cooler. some folks bypass it when they add an external monster. that's ok unless you're sitting in a 2-hour traffic jam.
Old Nov 3, 2006 | 08:54 AM
Casey's Avatar
Casey
Or backing a trailer. The air to oil cooler out front doesn't get any airflow in reverse, so it's almost useless when backing a trailer.
Keep the cooler in the radiator. It's there for a reason.
Old Nov 3, 2006 | 09:17 AM
lossscause's Avatar
lossscause
thanks guys, i gues my best bet IS to flush it. is there any way to replace it? would that be better?
Old Nov 3, 2006 | 09:31 AM
Cuda_jim's Avatar
Cuda_jim
If you replace the stock cooler and bypass the in-rad cooler it will take forever to get the tranny up to operating temperature, especially if you drive short trips or live in the colder climates. LEave the in-rad cooler hooked up or Get a cooler with a thermostat (thermal break). Trannys need to run hotter than 120 degrees IMO.
Old Nov 3, 2006 | 09:51 AM
lossscause's Avatar
lossscause
I agree, do you think I should switch over to synthetic oil now?
Old Nov 3, 2006 | 11:28 AM
DaBigTow's Avatar
DaBigTow
Synthetic (Mercon- compatible) trans juice is a good thing. I run Mobil 1; about 50k miles per change, double what I run dinosaur oil. Syn handles the heat better. I also use 1-1/2 bottles of red LubeGuard per tranny change.
baldboyford
Jun 6, 2017 04:02 AM
ed foster
Mar 15, 2017 01:35 PM
badass_f250
Sep 17, 2015 11:16 PM
1949ply
Apr 29, 2015 05:19 PM
Woodsman_30350
Jun 18, 2008 04:54 PM
