Blue dash lights
Old Nov 2, 2006 | 04:23 PM
79 FORD's Avatar
79 FORD
Blue dash lights
I have been wondering for a while if I was to remove my gauges and replace the bulbs with blue ones would it change the lights to blue or are the numbers green with a white light? If anyone knows if this would work I would like to know and comments are welcome.
thanks,
Bob
Old Nov 2, 2006 | 05:16 PM
arctic y block's Avatar
arctic y block
Wink
Put all blue light in my 55 after converting to twelve volt. They ar'nt as bright. A hole lot softer. I love em for night driving. But each to his own. Try it . it is easy to change back.
Old Nov 2, 2006 | 05:34 PM
1975Ford's Avatar
1975Ford
I put blue lights on my tach and my aftermarket guages, installed the blue light on my instrument panel, my truck a 1976 F150, it was like attic y block mentioned. The guages are a subtle shade of blue. I like the light affect too.
Old Nov 2, 2006 | 08:01 PM
gbrett's Avatar
gbrett
well the bulbs are white and so I am not sure how blue it will look
Old Nov 2, 2006 | 11:14 PM
Mil1ion's Avatar
Mil1ion
ART class 101
Yellow bulbs with blue lens = Green (stock Ford)
White with blue lens = Green ( lighter green that is)
Blue bulbs with blue light = Blue (but can hardly see anything)
Blue bulbs without the blue lens...= Light Blue
Old Nov 3, 2006 | 04:34 PM
79 FORD's Avatar
79 FORD
So by my logic if I were to put in red bulbs the light would be a dull purple?
Old Nov 3, 2006 | 04:36 PM
FordPickup460's Avatar
FordPickup460
I put red bulbs in for my gauges, I took the blue filters out. I used blue bulbs for my turn signal indicators.
Old Nov 3, 2006 | 04:40 PM
79 FORD's Avatar
79 FORD
How does that look?
Old Nov 3, 2006 | 04:50 PM
FordPickup460
It looks good to me. I can see the gauges just fine, and they match my stereo and CB lights.
Old Nov 4, 2006 | 01:30 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
Not really no, but there are a lot of factors to consider.
IS the bulb covers on the cluster blue lenses or is it a blue light filter?
I used to do stage lighting, and it's more complicated than and very different than mixing paint.
Yellow Light is a mixture of Green and Blue light. Just like your tv set. Red, Green, Blue.
Put a blue filter in front of a yellow light it blocks the blue light, and passes the green. It also cuts the intensity of the light down by 50%.
Put a blue lens in front of a yellow, light, it will only pass the blue light, and filters all the other light. In this example green is blocked. This also cuts the intensity by 50%.
So it depends on what type of "Lens" is on the cluster. I believe it's a filter. IE: Green light from yellow.
So to answer your question,
Red light through a blue filter, will pass the Red light. Infact if your bulbs were purple, passing it through a blue filter will change it to Red.
Red Light through a blue lens, will block all or most of the red light, therefore, no light to see.
Remember,
White light, is a mixture of all the colors of the spectrum.
Yellow Light is a mixture of Green and Blue Light.
And the incandecent bulbs, although yellow in appearence, still has a lot of "other colors" mixed in at different brightness levels then just blue and green, but blue and green are the brightest, with red being just a little less bright etc...
It's not an exact science cause there are too many variables, brightness, focal points, etc to count, off the top of my head. But hopefully you get the meanings.
Hope this helped.
Old Nov 4, 2006 | 03:15 PM
Mil1ion's Avatar
Mil1ion
Ralph sorry man I have to disagree.
Green & Blue Doesnt make yellow .
It has always been proven .....Yellow & Blue makes Green
That's what make our trucks clusters illuminate Green
Yellow Tungsten light bulb mixed with Blue Filter - Grren Illumination
http://www.teachers.net/lessons/posts/1352.html
Old Nov 4, 2006 | 05:00 PM
81-F-150-Explorer
Hi Dennis.
Your school chart is how paint is mixed, which is different than how light is mixed.
Don't feel bad, I made a slight mistake in the last chart I made as well.
Mixing paint:
Yellow and Blue make green.
Mixing Light:
Green and Red make yellow light.
Here is a website that explains it better than I can, and is less prone to errors on my part.
http://home.att.net/~RTRUSCIO/COLORSYS.htm
Old Nov 6, 2006 | 09:31 AM
1975Ford's Avatar
1975Ford
I put the blue lights.
Yes the instrument panel does have a fade of greenish tint when the istrument panel lit.
I have aftermarket guages with the white panel. These also have a greenish tint on back panel. I used blue bulbs.
