Temp gauge reading help
Old Nov 2, 2006 | 02:51 PM
oem78's Avatar
oem78
I have a 1979 F150 with a 300 6 cy 4spd 4x4. It over heated, and steamed all over. The radiator was rebuilt and the thermostat replaced. Before it was rebuilt the temp guage would go to hot, right when I started the truck then cool only slightly. Now the guage starts all the way to the left when I start the truck , it slowly moves the the right toward hot to the A letter on NORMAL then moves back down to the M or R area on NORMAL. Is this ok or is it running hot, or should it be toward the N or O ? MY old truck a 1978 with a 400 always ran at the N or O.
Old Nov 2, 2006 | 09:19 PM
carrfamilynj's Avatar
carrfamilynj
Sounds like it's exactly where it should be-it will go slightly higher when you first start it, until the thermostat opens and lets the cold coolant into the engine, that's when you see it drop.
GreenMachinee
Dec 3, 2014 04:57 PM
rhildebrand
17
Aug 7, 2014 07:32 AM
whenry912
16
Oct 27, 2010 12:13 PM
Oversize
Aug 11, 2009 09:32 PM
81
Jan 7, 2004 12:39 AM
