Running Hot but only after a while?
Old Sep 14, 2010 | 07:19 PM
whenry912's Avatar
whenry912
Hello all,
New issue here, took the truck on a 20 mile trip to work and back. Both ways, the truck's temp moved up as would be expected as it warmed up. Went to the "N" on normal, then stopped there, which I assume is the Thermostat opening. Stayed at the "N" for 5 miles. Now after 10 miles into the trip, starts to creep up every time I applied ANY throttle, and creeped up a bunch on hills... made it the final 10 miles, went from the "N" to the "L" during the last 10 miles. When I stopped the truck felt very hot, not quite boiling over, but the overflow tank was quite a bit more full.
So, why would the motor warm up for 5 miles, stay the same for 5 miles, then slowly start to overheat?
Thermostat is the correct Ford model, and I know I need a real temp guage but I thought this was strange and someone might have an idea...
Thanks!!!
Old Sep 14, 2010 | 07:43 PM
gnathv's Avatar
gnathv
Probably clutch fan not engaging or radiator clogged up and not circulating as it should. How does your coolant look? Is it clean or does it look rusty and cruddy. If clean I would look at fan first.
Old Sep 14, 2010 | 07:52 PM
whenry912's Avatar
whenry912
Coolant is clean and brand new because I just drained it to do the head gaskets... PO had Blue Devil head gasket sealer in it to try to fix the leak, so this looks like a poorly flowing radiator?
Old Sep 14, 2010 | 08:08 PM
oreocreaming's Avatar
oreocreaming
it could be the radiator fan clutch like gnathv said. get it warm, just right before it overheats...... then shut it down, hop out real quick and try to turn the fan by hand. if it still spins freely then its the clutch. if its locked up or damn near locked up then your good.
Old Sep 14, 2010 | 08:14 PM
charleswood6969's Avatar
charleswood6969
Could be your water pump impeller spinning on it's shaft too. Original water-pump or has it been replaced?
Old Sep 14, 2010 | 08:22 PM
whenry912's Avatar
whenry912
Water pump has 26k miles on it, no idea about age of Fan Clutch, Radiator was replaced by the PO 47k miles ago but was a junk yard part out of an 88 F250... looks like it has some calcification inside and looks pretty old...
So would the truck hold a good temp for 10 miles then slowly get hotter if the radiator was clogged? When I got home I left it idle and the temp slowly came down from the "L" to the "M" before I shut it down.
Old Sep 15, 2010 | 07:28 AM
1994F2507.3L's Avatar
1994F2507.3L
mine did the same thing but it was the gauge..... got my mechanical in and she sits between 185-195 down the highway at 80-90 degrees outside
charleswood6969
Are you sure it is the right radiator? These old IDI's had a HUGE radiator in them. If the PO grabbed just any old radiator from an F250, he might have grabbed a gasser radiator. It would keep it running for awhile, until it got clogged up, even minorly, and them you are gonna have overheating issues. You sure wouldn't have enough cooling capacity to tow anything, and even running at 65 mph.
Are you blowing bubbles out of the radiator, indicating a head gasket leak or cavitation blowing air into your coolant? Any coolant into the oil? Either one would be indications, along with overheating, that you have serious problems. As it is, either you have a radiator or a water pump issue.
Old Sep 15, 2010 | 07:30 AM
1994F2507.3L
List: Radiator - 1994 Ford F-250 | O'Reilly Auto Parts
here's a couple radiators
Old Sep 15, 2010 | 09:17 AM
whenry912's Avatar
whenry912
Yep, it is a 7.3 idi radiator, but it definitely has seen better days...
Ordered a lifetime guarantee new one from Autozone, $305 shipped to my door...
Thanks for the confirmation of what I feared, all I can say is this truck should run really well since I have replaced almost everything now!
Old Oct 26, 2010 | 11:36 PM
Irishdntply's Avatar
Irishdntply
Your problem
I had the same exact problem. Not sure if you figured it out by now but I can ALMOST bet you it is your water pump once again. The POS water pump impellors (plastic) suck on this things. Mine impellor was cracked just enough that it would run perfect temps when idling or not in the throttle.
However if you got into a higher rev. like 2k then the truck would immediately start running hot, when you let off the truck went back to normal. Sorry for the spelling I'm not a english teacher or anything, just trying to help out my fellow ford 6.0 diesel guys/gals.
Old Oct 27, 2010 | 03:19 AM
'88 E-350's Avatar
'88 E-350
I hope you'll let us know if the radiator solved it, good for the next guy.
Old Oct 27, 2010 | 07:11 AM
jeffreythree's Avatar
jeffreythree
I just fixed a similar problem. Ran some Prestone flush through it a couple of times and it helped quite a bit, cleaned a lot of crud out of the radiator. Fan clutch fixed it for good since temp still climbed during stop and go driving, highway and idling ran cool with the clean radiator.
Old Oct 27, 2010 | 09:22 AM
whenry912's Avatar
whenry912
Sorry, been dealing with other issues, but yes, the new radiator solved the problem 100%... in fact it almost runs TOO cool! Driving the truck, the factory sucky gauge comes up quickly to the N on Normal and stays there all day long, hot, cold, A/C or heat on, hills or flats... So for the record, this one is in the books...
Old Oct 27, 2010 | 09:28 AM
wreckinball's Avatar
wreckinball
who has a 6.0....what the hell? where have i been? hahaha
