Aerostar Ford Aerostar
Fuel pump
Old Nov 2, 2006 | 12:18 PM
Dknydo's Avatar
Dknydo
Fuel pump
Hey guys/gals,
I have question that I cant seem to find the answer to. I have replaced the fuel pump in the gas tank, however it is making a really loud whale like sound. It seems to be resonating through out the car. Whats causing this? Is there something I can do to keep it from making all this noise?
Help !!!!
Dknydo
Old Nov 2, 2006 | 01:21 PM
aerocolorado's Avatar
aerocolorado
Its normal for them to make a fairly noticeable whine when running. Should be just barely audible from within the van. Aftermarket pumps may use a different motor and therefore make a different type/decibel level of sound. This could be your case.
Old Nov 2, 2006 | 01:34 PM
Dknydo's Avatar
Dknydo
Oh its definitly audible,,,Makes a terriable whine. Its the second one two, mind you its from the same parts store. Would using some cork to line the straps help?, and what about using some between the tank and the bottom of the van??
Old Nov 2, 2006 | 02:31 PM
aerocolorado
The tank is plastic which helps negate a considerable amount of sound wave transfer. I doubt if adding cork to the straps would do much. Might be a better tactic to try and insulate the tank with a sound deadener material. They sell this by the sheets at some parts stores. Its a silver, laminated affair.
-On edit: Its similar to this: http://www.b-quiet.com/extreme.html
Old Nov 2, 2006 | 04:00 PM
jetfiremuck's Avatar
jetfiremuck
Are you sure its not the air bypass on the throttle body.Does the noise go away if you bring the revs up
Old Nov 3, 2006 | 12:21 AM
Pablo-UA's Avatar
Pablo-UA
Original Motorcraft fuel pump is loud when it is new, Bosh pumps are silent.
These pumps are different. There are rollers inside the Motorcraft pump (I tried to disaasembly it), the Bosch pump has a small turbine inside, that's why noise of it is hissing, but slight.
Old Nov 3, 2006 | 01:53 AM
xlt4wd90's Avatar
xlt4wd90
Make sure that the tank is sitting in the proper position, and that the top cap on the tank is not somehow contacting the floor board.
bigedusa
1983 - 2012 Ranger & B-Series
Oct 19, 2015 02:12 AM
MIKEDEL
Jun 10, 2014 12:24 PM
NS F250
35
Feb 4, 2014 08:50 PM
Florida Native 72
Dec 17, 2011 09:42 AM
troposcatter
Nov 11, 2003 02:31 PM
