Sponsored by: Real Truck
Heater/AC not working
Old Nov 2, 2006 | 08:27 AM
dlpinkc's Avatar
dlpinkc
This morning when I left it was a bit chilly. Tried to turn on some heat and nothing....no lights, no nothing.
Came back home to check fuses. Still not sure what fuse it is, but I believe it is number 24 (05 F250). Anyway. Didn't look bad, couldn't find my mult-meter. Took the radio fuse out and switched it with fuse 24.
Both radio and heat now work.....
Bad connection at the fuse? or should I look further?? Heading up north for Thanksgiving and would hate to be on the road and have no heat....in case it is cold.
Thanks for any ideas.
dp
Old Nov 2, 2006 | 08:48 AM
kw5413's Avatar
kw5413
Hope this helps..
Various Electronic and Driveability Symptoms and Codes:
2005 F-Super Duty trucks built before 5-11-05 may exhibit various electronic-related symptoms due to loose/miss-installed fuses in the engine compartment fuse box. These symptoms may be intermittent. The fuses should be inspected to verify they are installed into the terminals in the fuse box and not along side the terminals.
Fuses--Symptoms
#9, 20 amp: Trailer turn signals inoperative
#10, 10 amp: Check Engine Light; Codes P1633, P0446
#11, 10 amp: Speedo bounce, ABS light, Cruise control inop; Codes U1900, U2023, P0500-P0503
#12, 2 amp: Cruise control inop, TBC Fault displayed, chime; Code C2803
#13, 15 amp: Day time running lamps inop
#15, 15 amp: Crank/no start, bucking, stall; Codes P2614, P2617, P1378
#17, 10 amp: A/C inop or not cooling
#18, 10 amp: Crank/no start, bucking, stall; P2614, P2617, P1378, P0611
#20, 10 amp: Trailer back up lamp inop
TSB 05-11-14
Old Nov 3, 2006 | 09:25 PM
sledwrecker's Avatar
sledwrecker
I had the same thing occur with my 05 F350 about 2 weeks ago, I did the same thing with the fuses, just pulled it and inspected it and reinstalled it. Bingo it worked.
Old Nov 4, 2006 | 09:44 AM
BowTieHatr's Avatar
BowTieHatr
i am assuming you have eatc. if so you need to go get your head replaced. i have put on several of these, and ford did have a broadcast message about this concern. its expensive unless you have esp or base warranty.
Old Nov 4, 2006 | 04:28 PM
GLAMIS's Avatar
GLAMIS
What is eatc?
Old Nov 4, 2006 | 06:41 PM
BowTieHatr's Avatar
BowTieHatr
Electronic Automatic Temperture Control
Old Nov 5, 2006 | 07:04 AM
dlpinkc's Avatar
dlpinkc
I'm not understanding. I'm relatively certain this problem was electrical in nature, since pulling a fuse and re-installing it solved the problem (at least so far it has). Why would I need to have a head replaced?
EATC?
dp
Old Nov 5, 2006 | 08:31 AM
BowTieHatr's Avatar
BowTieHatr
do you have eatc? the heads are having a problem mainly when you shut the truck off. they are too sensitive and something is giving them a shock. these heads are mini computers and when you pull the fuse you are resetting the head causing them to work. yes, the problem is solved but i am very certain it will happen again. see it too many times.
Old Feb 13, 2008 | 07:01 PM
elkhorn's Avatar
elkhorn
could you shed some lite on the Ford broadcast message? THis just happened to my 05 EATC, no power, haven't done anything yet. Would the dealer know about it?
Super Duty Daddy
May 11, 2019 08:02 PM
2006powerstroke90
Jul 28, 2014 03:48 PM
Super Duty Daddy
Electrical Systems/Wiring
Oct 7, 2013 08:27 PM
kovi
Aug 26, 2013 02:30 PM
don9235
2004 - 2008 F150
Jul 15, 2011 01:22 PM
